wanna to build a good reliable home PS. which can provide up
to say 10A with regulated + & - volts up to say 40V. i know itsnt that easy project to build ... but anyone has schematics for a similar PS.? or even a good design guide? thanks.. |
#2 |
Guest
that's 400Va,your best bet would be to but a toridal transformer and run the secondarity through a full wave bridge and then into some caps for filtering.
#3 |
My friend (I did read your other postings and I think I am on your side)
Could you please chAnge that Schmashy, thIng it so hurts my eYes. I was forced into an 85 year old avatar by one of the grey ones (oldies) and I think that ticks them off way more than banging around, please my eYess 8o) keep up the good work, but please lower the noise. ps. give them the mirror, the mirror, dude
alleen vragen |
#4 |
Loose your anger and I will send your schematics.
What is your local outlet voltage and what are you gona use it for. Old Man just waiting to talk
alleen vragen |
#5 |
I must apologize for not having a schematic to hand, but I hope this will make enough sense to be of some help.
I would build two 40V psus based on standard regulators - like LM317 - but add a spritely high power, slave bipolar to handle the current - like an MJ15022. LM317 datasheets usually show how to do this. This way you get all the benefits of a sophisticated regulator. Then just connect the two 40V psus in series. You only need one, dual-secondary transformer. BAM |
#6 |
ive build my 1st PS. along time ago its +12/-12/+5/-5 3A one
the outlet volt in here is 220 , i just need to build a very good PS. that can handle as i told b4 about 10A or maybe more current with regulation upto say 40V. so i can test my upcomings Amp. projects. (eg. the smallest and the only one i made is a TDA1554 one IC 12v. car amplifier so sure it cannt be properly tested with my current one (3A Max.) and so on.... the only schematic ive found online is for the LM338K IC regulator but its 5A, upto 30V and no neg. output (only + and ground).. here its.. |
#7 |
#1:
The potentiometer needs to be connected as reostat with wiper and one leg connected or otherwise your output voltage will go to rail-1.25 V when the wiper looses contacts with the track. #2: Read this: Regulated bench PSU #3 Previous post gave you directions. /UrSv |
#8 |
There are some 10A regulators like LT1038.
The problem is to handle the dissipation if you need a very low voltage at that currents. The easiest solution is always a variable AC-voltage source (variac) followed by a rectifier and some caps. But that might be cost intensive if you don´t get it second-hand. I´ve seen a lot good offers on Ebay but haven´t bought one myself so far. Maybe you could keep good contact with the repairshop near your place and just take your finished project there and use their variacs? You´re always welcome in our shop and use ours if you´re in germany Jens |
#9 |
you also want to put a diode across the regulator to allow a path for the caps to discharge (rather than discharging through the regulator.)
#10 | |
On Hiatus
But if any TUBE guy comes in here (because of your Thread-name) and wants real high voltage regulator, here is one alternative. It can put out 100mA and over 400 volts, APEX PA88 op-amp in TO3 8-pin PA88 High Voltage Power Operational Amplifier FEATURES, HIGH VOLTAGE - 450V (±225V). LOW QUIESCENT CURRENT - 2mA. HIGH OUTPUT CURRENT - 100mA. |
| Do SMPS have a home at high end audio? | Jay | Tubes / Valves | 69 | 4th February 2010 11:00 AM |
| High voltage, high current super regulator, possible group buy | peranders | Group Buys | 54 | 2nd June 2009 09:43 AM |
| high current vs high voltage power | Clipped | Car Audio | 28 | 19th April 2007 06:06 PM |
| 6BY5 High Voltage & High Current Choke Input Design P.S. | snoopyma | Tubes / Valves | 7 | 28th June 2006 01:32 PM |
| high volt amp (dumb theory) | Pbassred | Solid State | 1 | 18th April 2004 11:18 AM |
| Page generated in 0.09992 seconds (79.23% PHP - 20.77% MySQL) with 11 queries |
