#21 | |
Now coinsider two loads, A and B. A) needs 40V and draws 10A B) needs 10V and draws 10A Load A will dissipate 40*10 = 400W, while load B will only dissipate 10*10 = 100W. However, in a linear regulator we have a pass transistor in series with the load, and this transistor must drop the difference between the 50V and the load voltage. For load A, the transistor need only drop 50 - 40 = 10 V, so it will dissipate a power of 10V*10A = 100W. However, for load B it needs to drop 50 - 10 = 40V, so it must dissipate 40*10 = 400W. That is, the lower the output voltage, the higher the voltage drop over the pass transistor. For the same current, it will be hotter for smaller output currents. Of course, there is only a problem if you have loads that draw high currents at low voltages. Some PSUs have a foldback protection so they are limited at a lower current for low voltages. |
#22 |
This design is modified from Horowitz and Hill and it works, it really works -- but you are going to have to add compensation. I found that the values in H&H and those which kept the device stable were different and no doubt you will the same. -- depends on the OPAMPs and the MOSFET's. <p>I use a 10 bit serial DAC from Maxim, since I have several laying around and have already written the code, but you can just tie the Inverting input of the opamp to +5 volt reference via a 10K resistor and adjust the voltage via the potentiometer (which is how it is described in H&H.)
Jack |
#23 | |
well, after undestanding the dissipation prob. i dont think that am going to face it since this ps. will specifically be used for testing any upcoming amplifiers like the P3A and alike ones.. so i made it more easy now ithink, i dont know yet any volt. regulator except that LT1038 but it only can be regulated to 32V with 10A max. is this suitable for the P3A and alike ones?? |
#24 | |
#25 |
i can take the P3A project. volt. & current req. as a mesurement
level to put the PS. volt/current range i need. so any one know the max. consumption current for the P3A when running with +35/-35 volts. providing 100watt into 4ohm.?? |
| Do SMPS have a home at high end audio? | Jay | Tubes / Valves | 72 | 1st September 2012 04:04 AM |
| High voltage, high current super regulator, possible group buy | peranders | Group Buys | 54 | 2nd June 2009 09:43 AM |
| high current vs high voltage power | Clipped | Car Audio | 28 | 19th April 2007 06:06 PM |
| 6BY5 High Voltage & High Current Choke Input Design P.S. | snoopyma | Tubes / Valves | 7 | 28th June 2006 01:32 PM |
| high volt amp (dumb theory) | Pbassred | Solid State | 1 | 18th April 2004 11:18 AM |
