diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   dual center tap rectifier replacement (http://www.diyaudio.com/forums/solid-state/83907-dual-center-tap-rectifier-replacement.html)
dodgerblue 29th July 2006 06:03 AM
any soft recovery replacement the IRF16JPF and IRF16CPF series to-247 rectifiers, having a hard time finding both pos. and neg. output pairs !
AndrewT 29th July 2006 07:38 AM
IR do not have these device numbers in their product search.
Check your numbers.
dodgerblue 29th July 2006 03:06 PM
irf 16cpf10 and irf 16jpf10 , late night post ! thx. andrew
AndrewT 29th July 2006 03:26 PM
I still cannot find your codes in the irf search
Have you gone to www.irf.com and done a search?
dodgerblue 29th July 2006 03:40 PM
yes i have a copy of the data sheet ,part was made in the early 80,s!data sheet no. pd-2.193,dual centertap pos. and neg output rectifiers
AndrewT 30th July 2006 08:30 AM
Rapid show three dual diodes in their catalogue, 2*15A, 2*14A, 2*30A all made by ST.
I think they are all fast for switch mode, the 15 & 30 are described as ultrafast , soft & noise-free recovery.
I suspect RS & Farnell will have similar.
I use www.rapidonline.com a lot. They are cheap (in UK) fast, free post on orders over 25.
I see the online has no 30A version.
dodgerblue 31st July 2006 05:26 PM
thank you for the help andrew,what im finding difficult to find is a pair of soft recovery low trr dual center tapped rectifiers one with a common cathode and the other with a common anode in the 247 case no less than 10a per leg no less than 100v any other reccomendations?
Resources saved on this page: MySQL 18.75%
