Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 24th July 2006, 04:18 PM   #1
Default Whats this for?
What is R14 for in this picture. It is Doug Selfs Blameless Class B amp.
Old 24th July 2006, 04:24 PM   #2
Did it Himself
richie00boy's Avatar
It changes the slope of the thermal compensation mV/degC.
And yes, there are capacitors in the circuit. One is even employed to form the dreaded bootstrap on the voltage gain stage. Get over it.
-Burning Amplifier #2, Nelson Pass
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 24th July 2006, 04:41 PM   #3
mikeks is offline mikeks
Account Disabled
See Hawksford here
Old 24th July 2006, 04:42 PM   #4
I went and read the Hawksford paper on the circuit. My understanding from reading it is that this circuit will minimise the changes in the bias voltage based on changes in the current going through it. So it would then keep your bias voltage more stable for any changes temperature wise in your VAS stage.
So, richie00boy, your saying you can change your compensation slope as well? You could then change it from -2 mV/degC to -3 mV/degC or what ever you want to put it at by changing the R14 resistance?
Old 24th July 2006, 05:13 PM   #5
Account Disabled
Originally posted by davidallancole
..... this circuit will minimise the changes in the bias voltage based on changes in the current going through it.
Correct.
Old 24th July 2006, 05:45 PM   #6
sreten is offline sreten
From what I remember from Selfs book :
it changes the slope of the Ivas vs Vb curve to a gently peaking
characteristic, with the right value you can set Vb to be in the middle
of this peak. Consequently Vq thus Iq becomes less dependent on
ambient temperature, variations in mains voltage and power supply
droop.
It does not change the thermal compensation mV/C in Selfs design.
Its purpose is to stabilise Vq, i.e. in Hawkfords paper R3opt is used.
Self shows elsewhere in his book how to manipulate mV/C of the bias.
/sreten.
Thread Tools
Whats should I do???? kino-schmid Solid State 6 1st March 2009 07:15 PM
whats this... tomtt Everything Else 18 17th May 2007 06:15 PM
Page generated in 0.15690899 seconds (75.78% PHP - 24.22% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
