#11 |
I momentarily posted another circuit, till I realized that the current limiting resistor is in the emitter of the Q401. Grrr....
This ought to work...just add the two diodes and the power resistor and the cap. Should pull the base down ASAP and turn the transistor off when powered down. Might have to play with the cap value...22µf might be too big. 10µf maybe... |
#12 | |
I will get the parts and try this. Thanks. Glen |
#13 |
Worth a shot...
Note that the point of connection of the first 1N4004 is not at the filter caps, but directly from the output of the transformer. This is critical, so that as soon as the switch is turned off, the voltage is lost (as opposed to the voltage on the big 16,800µf 75V caps, which takes forever to bleed off). The amp also has a separate 6.3V winding for the lamps, which would have been great to use, except with the limiting resistor in the emitter of the relay driver transistor the base will be at too high a voltage for that. So you're stuck with getting the voltage from the high-voltage / high-current winding. |
#14 | |
#15 | |||
#16 |
Good job!
I was intending the entire relay circuit to be powered by the half-wave rectifier, but EchoWars variation works just as well. It may be easier to retrofit because it does not require any existing wiring to be changed. Please consider changing R403 and R407 too. |
#17 | |
| Full-turn/partial-turn pots | slowpogo | Parts | 1 | 12th January 2007 08:40 AM |
| How can I reduce mechanical turn on and turn off noise? | soundNERD | Chip Amps | 8 | 28th October 2003 02:43 AM |
| Page generated in 0.09955 seconds (77.73% PHP - 22.27% MySQL) with 11 queries |
