Old 19th July 2006, 07:48 AM   #1
Glarf is offline Glarf  Australia
Default NAD 304 Transformer?
I have an NAD 304 amp - sounds fantastic and works well, but it's developed an increasingly audible buzz from the transformer, which is annoying in the small, quiet room it's in (it's supposed to supply 'mood music' for paying dinner guests)...
The amp's a bit old, and this problem has developed over time and the buzz from the transformer seems to be slowly getting louder.
When I sent it in for a service, the NAD parts supplier in Australia informed me that the problem is indeed with the transformer ("Ya Ning GTR4. 700. 875"), but that it's no longer in production, and that they can't get me a direct replacement either from Australia or elsewhere within NAD's service network.
Wondering if anyone can help suggest where I might get a replacement transformer for the NAD 304 - either the same transformer or something that'll serve as a good replacement (and is more or less equivalent in size).
I don't know much about electronics or amp circuitry, but replacing the transformer won't be too difficult. Any help anyone can offer is much appreciated!
Old 19th July 2006, 06:18 PM   #2
post a photo of the transformer, there are a few
tricks to try, but it depends in the way it is made.
/sreten.
Old 19th July 2006, 09:55 PM   #3
jaycee is offline jaycee  United Kingdom
Measure the voltage of it's outputs. If youre lucky it's a single centre tapped secondary and you can buy a similar transformer anywhere.
Old 21st July 2006, 09:37 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Actually the secondaries are HxV-LxV-0V-LxV-HxV,they give around 50 something and 30 something after rectification.
Old 21st July 2006, 02:32 PM   #5
Default NAD 304
you can find Servicemanual 304 at www.sharefx.com
Old 21st July 2006, 04:36 PM   #6
is the 304 the model that had selectable voltage to suit either 8ohm or 4ohm load?
If so, it should still be easy to obtain a close replacement to suit the high or low load requirement.
To create an identical two tap version would need some rewinding of the secondaries.
regards Andrew T.
Old 21st July 2006, 04:52 PM   #7
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
Noise is problably on of the shielding plates surrounding transformer that's vibrating. Try to put one washer between chassie and one of mountings of transformer to twist plates a tiny bit, it may help.
Or buy some plastic spray for use in electronics to fill hollow spaces between plates.
/ Anders
Old 23rd July 2006, 07:04 AM   #8
Lots of responses, looks like I came to the right place. Thanks guys
4fun
That's what I began thinking immediately after I posted - really don't know much about electronics so (as lazy as it sounds) I'd prefer to think it's a "mechanical" problem (as so many problems are). Will definitely try this first...
derguteton
Thanks, downloaded it already!
sreten
post a photo of the transformer, there are a few tricks to try, but it depends in the way it is made.
Will do this - I'll try dampening it first (as per 4fun's suggestion), if that doesn't work I'll pull it out, take a photo and post it here.
Leolabs
jaycee
Will read around, see if I can figure out where I should be probing. Apologies, as I said I'm just learning (I realise there's probably a little prior knowledge expected on this forum). Appreciate your help and patience guys!
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.09312 seconds (86.29% PHP - 13.71% MySQL) with 10 queries
