Is my amp in danger?
Old 17th July 2006, 05:08 AM   #1
mudihan is offline mudihan  United States
Default Is my amp in danger?
I have been using OPA637s in the input buffer stage of my NHTPro A10 power amp (150W per channel, dual mono). The result is amazing as the sound has been vastly improved. However, the buffer stage is set at unity gain -- the OPA637 are not supposed to be stable at this lower gain. But I can't hear anything wrong. Everything is so smooth and clean. Is it because the 56p bypass capacitors that may have solved the problem of oscillation? Or are my OPA637s timed bombs? Thanks!
Old 17th July 2006, 05:13 AM   #2
Schematic
Old 17th July 2006, 05:15 AM   #3
Can't upload the schematic
Old 17th July 2006, 05:18 AM   #4
never mind
Old 17th July 2006, 05:45 AM   #5
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
I've tried OPA637 in the I/V of DAC. It becomes oscilator. You touch the body of OPA637, is it hot? If it is, then you should look under osciloscope if there is oscilation when this chip is used as buffer.
Old 17th July 2006, 05:50 AM   #6
They are cool even after hours of playing.
So, as long as oscillation is not present, the opamp is in stable condition?
Old 17th July 2006, 06:35 AM   #7
jrdmedford is offline jrdmedford  United States
I'd not disregard manufacturers recommendations. You must have simply
gotten lucky with stability with a random sample of parts. Do you really want
to trust your power stage and speakers to this?
I really like the AD826 awhole lot... This device is unity-gain stable and is, in fact,
designed with the intentions of being a buffer. It can drive 50 ohm impedances
with tens of mA of current. Further, the op-amps output stage is Class AB, so,
for small signal excursions, the op-amp is running Class A. People like the
AD826. It's a $5 part too.
-- Jim
Old 17th July 2006, 07:19 AM   #8
I like AD826 a lot too. It's different from BB chips in a very confident way. And I think it sonically it outperforms many other AD chips, such as OP270, OP275, AD823, and AD827. However, I found OPA637 to sound best in my setup. The only things that came remotely close were AD843 and LT1364.
I actually have about 4 pairs of OPA637s (mounted on Browndog adapters) and all of them SEEM (they all sound great with no distortion or over-heating deteted) to be stable. (On the other hand, my pairs of OPA627 seem to get warm easily). It's just weird.
Again, something I really need to confirm:
Is oscillation the cause of instability? If the chip sounds great and is not over-heating, does this mean that there is no oscillation (or, what are the signs of oscillation -- I don't currently have a osciloscope)?
Many thanks!
Old 17th July 2006, 01:54 PM   #9
EchoWars is offline EchoWars  United States
EchoWars's Avatar
Many thanks!
Oscillation is the result of instability.
Scopes are cheap. A decent old super-reliable Tek 465 can be had for perhaps $350 (often less than that), and if you're fooling with DIY, a scope is not optional gear.
Old 17th July 2006, 03:58 PM   #10
Well, $350 is a bit too much for me. But your advice is well taken.
Is my amp in danger?Hide this!Advertise here!
Car Audio Danger Timn8ter Subwoofers 1 1st August 2007 01:10 PM
USA In Grave Danger!!!!! mikeks The Lounge 68 13th September 2004 05:22 PM
