can a sony ta-n611 be bridged?
Old 16th July 2006, 05:55 PM   #1
vibeline is offline vibeline  Canada
Default can a sony ta-n611 be bridged?
I have 2 old sony TA-N611 150 wpc amps.
Can I one amp to drive the right front speaker
and use the other to drive the left front speaker?
Can these amps be bridged?
How much power will they make bridged?
How would I hook it up?
Thanks in advance,
Old 16th July 2006, 07:30 PM   #2
claudiomas is offline claudiomas  France
claudiomas's Avatar
Send a message via MSN to claudiomas
detect the feedback resistor of the main amp . ground the input of iverted amp . double whit the same value this resistor and joint to the feedback inputs .just you need its 1 resistor .
overbiased
http://claudiomas.monsite-orange.fr/
Old 16th July 2006, 07:42 PM   #3
mikeks is offline mikeks  United Kingdom
Account Disabled
Default Re: can a sony ta-n611 be bridged?
Originally posted by vibeline
Can a sony ta-n611 be bridged?
The amp's PCB tracks in the output stage would have to be able to carry at least double the current..
Old 16th July 2006, 08:19 PM   #4
claudiomas's Avatar
wi need all ready two amps , one each channell R/L perfect conditions , ready to delyver 2x 125 watts each so we tray to get 250 watts each so the power supply can done whitouts any problems . of course whith an improved power supply you can get 2x500watts but it seem to me a dream .
overbiased
Old 16th July 2006, 08:25 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi vibeline,
Don't do this. Consumer grade amplifiers do not have the heatsinking, output stage or power supply to survive this. If you insist in destoying your equipment, you can buy bridging adapters. Do not start messing around inside your amp.
Other things to remember. An 8 R load looks like a 4 R load to a bridged amp. Output power may only double, a +3 dB difference that is hard to hear. Bridged amplifiers normally do not sound as good as the same amplifier running not bridged.
So, it's up to you.
-Chris
Old 16th July 2006, 08:35 PM   #6
claudiomas's Avatar
you can pass your life loocking boats start from your port and never tacking the large ocean . of course to double your engine will destroy your tyre and clutch calipers and driving licence but if you like this do it . really great forum .
overbiased
Old 16th July 2006, 08:40 PM   #7
Account Disabled
Originally posted by anatech
Hi vibeline,
True.
Far better to design a bridged amp. from scratch, or one that is specifically designed to operate in this mode.
Old 16th July 2006, 08:52 PM   #8
claudiomas's Avatar
Y use a SONY TAF3ES bridged by me from 4 years for my son yamaha electronic drums whit a 8ohm12'+compressor tweeter 1' , working many heures a day at full power whitout any problem anywhere . of course if you wont put af generator full charge and 4ohm fictive resistor it will be destroyed very soon . its raining d'ont go out .
overbiased
Old 16th July 2006, 08:56 PM   #9
Account Disabled
Good luck.
Old 16th July 2006, 09:45 PM   #10
anatech's Avatar
Hi claudiomas,
When I ran my audio service shop, I repaired more damage due to what you are recommending vibeline do.
So go feed the service guys, times are tough for them! But don't take anyone else down with you.
I am glad your gear hasn't blown up yet. Buy a lottery ticket!
-Chris
can a sony ta-n611 be bridged?Hide this!Advertise here!
Sony amp Ta-n611 output prob birch Solid State 0 17th August 2008 02:13 PM
Sony CDP-337ESD v Sony CDP-X33ES which is best? eldarvanyar Digital Source 0 10th January 2008 11:04 AM
Bridged amp pt.2 Gabevee Solid State 1 24th July 2002 03:11 PM
Copyright ©1999-2017 diyAudio
