Old 16th July 2006, 03:27 AM   #1
Default Welborne Labs MINIAMP kit, any advice?
Hello,
I am considering building myself a simple line-stage around these boards to replace an op-amp based pre-amp.
They are based on an Erno Borbely design. Does anyone have any experience with these or any advice?
Would they be an improvement over my BB OPA627s that I am using now?
http://www.welbornelabs.com/miniamp.htm
Any input is appreciated.
Best Regards
KevinLee
Old 17th July 2006, 07:15 PM   #2
Default I Built the Tube Hybrid Which Is Similar
I built the tube hybrid from Welborne which is the same concept as the unit you are considering and is also based on a Borberly design. I've had a little problem with DC offset drift, but they sound fantastic. I have them direct coupled so I adjust the DC offset once per week. I have them mounted in a Mark Levinson JC2 preamp chassis along with a VSPS phono stage. The boards are very high quality and I had no problems with assembly. Ron Welborne also offers good technical support.
Old 17th July 2006, 07:47 PM   #3
Thanks for the response,
I am glad to hear you are happy with the results.
I am still searching for a chassis to use, I will use the switching etc and replace the power supply and use the Welborne boards.
If anyone has a Rotel or Adcom pre-amp that is not working I would be interested in it.
Kevinlee
Old 17th July 2006, 08:10 PM   #4
I ended up with four external supplies in two Hammond cases, all from Welborne. I use separate supplies for each channel, which results in two filament supplies and two circuit supplies. Channel separation is phenominal. The Levinson chassis already had two XLR connectors, so I simply replaced those with the proper ones for connecting the power supplies - no drilling. Using the existing selector and wiring saved a lot of time. I replaced the potentiometer as the wirewound pot that came with the Levinson was noisy.
Good luck and enjoy!
Old 12th March 2007, 05:34 AM   #5
recca is offline recca  United States
Kevin
Did you actually put the Miniamp together? I'm thinking about building this too. It looks pretty simple to put together especially since I probably won't use a selector and use it strictly as a volume control.
Any thoughts would be appreciated.
Thanks!
Dave
FS: Welborne labs DRD300b (UK) mhl888 Swap Meet 0 11th March 2008 01:21 AM
Welborne Labs MiniAmp Linestage modules kit and parts KevinLee Swap Meet 0 30th October 2007 03:02 AM
Anyone have a Welborne Labs amp? benm Tubes / Valves 2 9th November 2006 12:33 AM
Welborne Labs Mod and ST-70 mstomaso Swap Meet 0 8th August 2005 07:53 PM
Page generated in 0.08011 seconds (73.12% PHP - 26.88% MySQL) with 10 queries
