diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   NAD 705 Troubleshooting (http://www.diyaudio.com/forums/solid-state/83189-nad-705-troubleshooting.html)
jocko_nc 14th July 2006 11:47 PM
All:
I just got a down-and-out NAD 705 receiver. The origanal owner had given up.
I'm new to this, thanks in advance for the advice.... I have to replace the lamps, that was easy enough to find. The protection circuit seems to work, unit powers up. I hear the output relays working. Once I figured out the input selector w/o help of the backlight lamps, I had a working receiver.
Problem: One channel is quieter than the other. I tested between A and B outputs, same result. Duh. I tested AUX and CD, same result. Now, I crossed the pre-outs and in and I got the quiet channel to switch sides. Hmmmm. That tells me I am looking for something messed up in the pre-amp. ????. What device in the preamp would cause all inputs to be quiet on one side? I can't see anything burned up or broken off hand. Not that I would expect, it works but has a gain screwed up or something. Any recommendations?
Thanks again. I AM looking for a good read on the subject....
Also, DC output on the amp channels read 20 mV and 40 mV. I have not tested putting another preamp OUT into the IN of the power amp section. I guess that would verify function of the power amps.
The various preamp level adjustments seem to be clean and functional. Moving them did not cause any level variations or indicate a problem.
jocko
anatech 14th July 2006 11:51 PM
Hi Jocko,
On some of these units they use a soft clipping circuit. It can cause trouble easily.
Try a "Y" plug from the pre out into the power amp input so you have a true mono signal. Is there still a level difference?
-Chris
Also, welcome to DiyAudio!
claudiomas 15th July 2006 07:07 PM
schematic diagrams??? have you a af generator and oscilloscope?
AKN 15th July 2006 07:19 PM
Re: NAD 705 Troubleshooting
Just take away bridge pins from pre-power plugs and connect phono cables in cross to verify if it's pre or powerstage level mismatch.
anatech 15th July 2006 07:29 PM
Hi claudiomas,
Who?
I have the equipment, but no schematic for this one or unit. I do remember the tough troubleshooting on a similar model.
-Chris
AKN 15th July 2006 07:50 PM
Sorry for my post, as i have not obviously not read your initial post carefully enough:smash:
claudiomas 15th July 2006 09:23 PM
preamps means lots of switchs and pots . 1rst clean and lubricate thems 2 renew soldering mainly on hot and eavey components. then whith Y connector to both preamps inputs 630/1Khz 0db compare whit your oscilloscope to find the trouble .
Resources saved on this page: MySQL 18.75%
