diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   removing a channel from an amp (http://www.diyaudio.com/forums/solid-state/83028-removing-channel-amp.html)
ol4554 12th July 2006 12:17 AM
2 Attachment(s)
Hello, I have a traynor beta 800 amplifier that has an a and b inputs and outputs.
I plugged it in when I got it, on one board a cap blew and a resistor was fried.
I am using this amp to amplify a bass guitar
Heres the million dollar question:
Can I take one of the boards out and just use one channel?
Tried
Tried taking the A input and connect to the board and blew fuses.
Is this possible to take out one of the boards and just use the other.
lndm 12th July 2006 07:01 AM
Could you just remove the fuses for the blown side? Only one concern, that the supply rails may be a little high with only one channel (probably okay, though best to check).
Copyright 1999-2017 diyAudio
