Old 11th July 2006, 09:14 AM   #1
Default Class B output power
how do I work it out? for
2sc3858 with 70 volts psu?
thanks
Old 11th July 2006, 09:28 AM   #2
Did it Himself
richie00boy's Avatar
What emitter resistors are you using and what load impedance?
Just work out total resistance in series with the load and then it's simple ohms law and potential divider theory assuming fully saturated transistors.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 11th July 2006, 05:37 PM   #3
Hi Riche, its 0.22 R, 8 ohms.
hope that helps.
Just wondering what I can get if I cool the output stage down, or then put it into class A.
Old 11th July 2006, 05:40 PM   #4
Did it Himself
Temperature or class is not a factor, that will just dictate how many output devices you need to cope with the heat and standing current.
Old 11th July 2006, 10:10 PM   #5
so for one device its .22r in series?
what about the series inductor etc.
amp has 4 parallel devices on each side....
so its 8/ 8.22 times 70volts minus drop across transistor and emitter resistor(10mv)?
Old 11th July 2006, 10:17 PM   #6
Did it Himself
it's simple ohms law...
work out parallel combination of emitter resistors
put this in series with load impedance
apply rail voltage (subtracting Vbe loss if you know it, otherwise guess at 5V)
what current flows
calculate power in load
rms power is half this
Old 12th July 2006, 09:25 AM   #7
ok assuminig 1 pair of devices, its
very close to 70-5 volts/ 8 ohms to give the maximum current for 8 ohms? about 8 amps
power =65 x that current? 512 watts ish...
And then half it for rms? 256?
why half it and not 0,707?
Where does the efficiency of the output stage come into it?
I am used to doing this with tubes, but transistors seem a little different.
If I turn the bias up, how do I tell when its all in class A? Power will reduce by about 2/3 I reckon.
std. Bias current is 45 milliamps.
thanks
Old 12th July 2006, 09:37 AM   #8
Did it Himself
Almost right but you have too much current because you have not included the other series resistances like I said.
RMS = peak*0.5 not 0.707 because it's power not voltage.
Output stage efficiency does not come into this calculation, that will be realised later when you add in the quiescent current and the total power drawn from the supply.
Turning up the bias to say 1 amp gives you 2 amps swing of class-a, assuming normal push-pull output stage.
Old 12th July 2006, 09:45 AM   #9
The reason you get half the power is that for power you are multiplying voltage with current, and these are either both peak values or both RMS values. If you multiply two RMS values you get 0.707*0.707 = 0.5 as compared to the peak values. Hence, RMS power is half the peak power.
Old 12th July 2006, 10:11 AM   #10
pinkmouse's Avatar
And, with 70V rails, a huge amount of heat!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Possible to design a high-power class D amp with a low output impedance? 454Casull Class D 2 23rd February 2009 07:33 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Thumb Rule for determining Approx output power of class AB amp rajeev luthra Solid State 12 3rd August 2004 07:34 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Page generated in 0.09905 seconds (78.02% PHP - 21.98% MySQL) with 10 queries
