Old 10th July 2006, 11:19 PM   #1
Quinn is offline Quinn  United States
Default Repairing Parasound HCA-2003
Ok,
I was given this parasound hca-2003 through a coworker. The power supply is messed up as you can see from the photos. I do dc-dc stuff (EE) at work but never mess with anything audio related. How hard would it be in your opinions to repair this amp, or should i just salvage the caps, and transformer and look to build something else.
Thanks for any insight whatsoever
"Todo we arnt in synchronous buck switcher land anymore"
Old 10th July 2006, 11:20 PM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Well more pictures would help. But what is the problem with the amp ?
Old 10th July 2006, 11:21 PM   #3
closeup of damage
Old 10th July 2006, 11:23 PM   #4
transformer, weighs a TON.
3 seperate windings, and 90,000uF of 80V output caps.
Its all in pieces, but the rest seems (from observation) to be ok.
Old 10th July 2006, 11:30 PM   #5
back of board, where burn mark is (obviously)
I was told it was a wife dusting fatality. I do not know what happens if the amp is turned on with all the stages hooked back together . Im going to assume nothing...
Old 10th July 2006, 11:30 PM   #6
Banned
It would be a nice amp to repair.. You could clean the amp up inside ( board ) with Rubbing Alcohol.
Old 10th July 2006, 11:35 PM   #7
Yeah, cleaning is the easy part, hhehehe.
I dont really know where to begin. Just was going to throw this post out there to make sure i wasnt going to overlook something common.
Ill keep you all updated with whatever i find.
Old 11th July 2006, 01:18 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi Quinn,
I'd start by buying a service manual from parasound. What I have seen so far is a little overheating. Have you done any troubleshooting so far?
-Chris
Old 11th July 2006, 01:36 AM   #9
i havnt even been able to turn the thing on, every board on the unit is diconnected.
they label connectors though, thank god
found more overheating signs
Old 11th July 2006, 01:42 AM   #10
anatech's Avatar
Hi Quinn,
Okay, so check whatever they may have told you. You can easily test the rectifiers, look for blown or missing fuses for clues. You can check the output transistors. If there are any regulators in there, check for bad solder joints.
What were you told about the initial problem?
-Chris
Parasound HCA 2003 3 channel power amp doerfast Swap Meet 0 22nd March 2009 10:49 PM
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 0 8th April 2006 07:29 AM
PCB GP by 09/30/2003 jrsun Pass Labs 13 30th September 2003 03:32 AM
Big Day Out 2003 griff Music 4 18th October 2002 11:52 PM
Page generated in 0.10770 seconds (81.11% PHP - 18.89% MySQL) with 11 queries
