Old 5th July 2006, 03:27 PM   #11
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I mean input pin directly on the amp board, AFTER the switch, not the RAC input jack on the box. Just to be sure. Do you have a coupling cap?
Aha! OK, I already have 47K directly on the input after the attenuator. No, there is no coupling cap.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 5th July 2006, 03:33 PM   #12
moamps is offline moamps  Croatia
Does it happen when you do not switch the sources' grounds?
Old 5th July 2006, 04:11 PM   #13
Nuuk's Avatar
Somebody had suggested not switching the source grounds Moamps and that would have been my next job.
But I tried something else first! I was using the 4 pole 3 way switch for two inputs and using the third position for mute. I had 47K resistors soldered across the pins of the switch. I changed the arrangement to make the switch a 2 way and did away with the resistors. And voila, no more noise when switching.
Fotios need help with input selector. Rotary switch or Relays? fotios Solid State 49 26th December 2010 12:31 PM
Phono input selector switch Woodsong Audio Analogue Source 21 6th March 2010 04:19 PM
toggle switch for input selector audio_moksha Tubes / Valves 25 14th November 2008 07:29 PM
simple 2 input selector switch for audio amp gychang Parts 6 12th March 2008 03:49 AM
Best sounding analog switch IC for input source selector rythmikaudio Solid State 10 28th February 2007 02:26 PM
Page generated in 0.07107 seconds (71.18% PHP - 28.82% MySQL) with 10 queries
