I am about to embark on an open-baffle loudspeaker project with 70s vintage 6 1/2 inch - 8" FR augmented by a 12" bass driver per channel--which may end up in a sealed enclosure if bass too light. First experiment on sheet of ply or MDF, later panels 38mm thick solid wood baffle with side panels. I plan on bi-amping using an active XO (adjustable between 80-120 Hz) and two stereo amps. I have the choice of several amps for bass and mid/treble use and seek advice on best combination. Drivers are reasonably efficient so power of amps should not be a great concern.
I appreciate that bass requires proportionally more power for same SPL etc, but Bass is a bonus, I am mainly after very clear midrange and treble. I have no objection to super-tweeter over 10kHz if necessary. Ruler-flat response is second to openness, clarity in midrange and "punch" or attack in midbass that I have found typical of single-driver enclosures. Amp choices Amp1 Luxman L-230 duobeta (15W Class A -> 63W Class AB) Amp 2 Luxman L-30 (30?W class AB?) Amp 3 Various chip amps ranging from 5 - 20W/channel. Amp 4 Old New Zealand made ~10W valve/tube amp-OK sound Amp 5 Old Pioneer valve/tube receiver ~15W/channel I was thinking L-30 up to 100Hz, L-230 or tube amp over100Hz, mainly because of the VERY nice class A sound of L-230. Comments/suggestions please.
"If at first you don't succeed--what's new" |
#2 |
Hi ozziozzi,
Good choice with the L-230. It's a pretty decent amplifier. Can your experiment with these or do you need to buy them? If you can keep them for a while it would be nice to play with them to see. I have found many tube amps do not have very clear highs, some do (I have a couple). The Luxman amplifiers tend to sound better than many others. The L-230 does have a nice clear top end. Relaxing. -Chris |
#3 |
I have L-230, L-30 and other amps I mentioned. i have just been auditioning a 12" driver (freestanding ie: nobox) with the L-230 and it sounds good bass and usable midrange a bit of "shout" in higher midrange especially if vol turned up. It probably only needs a tweeter XO at maybe 4KHz to fill out the top end. I haven't made any FR measurements yet. I always audition drivers in free air first at low power to see how they sound. i think SS amps certainly control drivers better than tube amps with output transformers--or am I talking thru my hat? i think that a tube amp on the top end could be sweet tho.
Thanks for your comments. Ozzi
#4 |
Hi ozziozzi,
Al I can say is that an enclosure changes everything. I use both tube and solid state amps and love both types if they are good. -Chris |
| What to do with Yamaha spkrs | jackinnj | Multi-Way | 2 | 20th December 2006 01:41 PM |
| Fullrange plus helper bass-suitable amps? | ozziozzi | Full Range | 3 | 9th July 2006 08:24 AM |
| Where to place the amps in bi-amped/tri-amped | Xicarius | Everything Else | 1 | 4th August 2004 12:13 PM |
| Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? | Layberinthius | Tubes / Valves | 0 | 11th March 2004 08:49 PM |
| Amps for tri-amped HT setup | dc | Digital Source | 6 | 29th March 2002 10:36 PM |
| Page generated in 0.07663 seconds (72.55% PHP - 27.45% MySQL) with 10 queries |
