Old 30th June 2006, 04:40 AM   #1
ostie01 is offline ostie01  Canada
Default Help me with my Denon POA1500(schem include)
Hi, I have a very nice denon POA1500, both channels were not working when I got it, now one channel works great and have troubles fix the other(right). Here is a link for some measurments I've made so if someone can help me resolve this problem.I can't get the +/- to be equal on the preamp side. Prior R11(-) and R9(+) it's ok(-7.26v,+7.24v) .After R9,R11, I measure 2.6v and -1.26v,both should be equal.
0v should be present and pin 7 of IC1 but the 1.34v is the difference between the 2.6v and the 1.26v.All power transistors are disconnected.But at connectors it's OK, +62.5v, -62.5v.D31 and D23 have only .2 to .3 voltage drop but I'm sure they're OK. IC3 is ok with +6.7v, -6.7v. Prior R41(2.7k 2w),62.5v and R57(2.7k 2w) -62.5v. Note that I have the same error at emitor of TR23 and TR27 which are connected to D23 and D31.Thanks for any help.
http://img49.imageshack.us/img49/413...poa15005qp.jpg
Old 30th June 2006, 04:46 AM   #2
Just forgot to mention, all cap have been by-passed,C11, C13, C49, C15, C19, all electrolytique are new. All transistors are new
Old 1st July 2006, 12:17 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi ostie01,
You would need to use diodes in place of the emitter base junctions of the power transistors for the circuit to "operate". Then you can get meaningful readings. TR7 seems to be on hard. Did you measure all the low value flame proof resistors yet? Darn things can be open and look just fine.
-Chris
Old 1st July 2006, 01:05 AM   #4
Hi, thanks for the reply. Every components have been remove prior measurment. Both channels work when I put back power transistor but at the base, I measure only .1 at .2 volts, normally about .6v should be measured at this point. Every transistors have also been remove for measurment. Q5 and Q3 were not original but were replaced with originals parts. Can you explain a bit more about diode at emiter-base junctions or power transistors.Thanks a lot.
Old 1st July 2006, 01:17 AM   #5
anatech's Avatar
Hi ostie01,
So you are saying your voltage measurments are with the power transistors connected?
The drivers need to have current flow to the output so the feedback works properly. A standard 1N4001 will provide close to the proper voltage drop. So just connect the diode in so it's forward biased if you don't want to have the outputs installed.
-Chris
Old 1st July 2006, 01:20 AM   #6
Thanks a lot. Look like you're a very active guy on this forum and very helpful too. Just keep up the good work. We need you.
Help to understand this schem please! apr Instruments and Amps 11 1st January 2009 08:06 PM
schem for LM1875 PCB missieek Chip Amps 1 29th October 2008 09:31 PM
Tip33.....anyone got a schem. diesel_tech Solid State 9 23rd March 2007 11:55 PM
Audiophilenoob--contact me if you want to be include in the Leach Board GP gengis Everything Else 0 9th June 2005 08:40 PM
help, schem for sherwood psychosteve Solid State 0 10th November 2004 05:35 PM
Page generated in 0.08451 seconds (75.11% PHP - 24.89% MySQL) with 10 queries
