All,
Looking at the replacement of electrolytics in several second-hand amplifiers, I wonder whether surface-mount multilayer ceramic capacitors are a good replacement for a low-voltage tantalium where bias problems may occur (such as with C2 in a Quad 405). The advantage is that they're small while large-capacity values are available. Such capacitors are often used in digital (i.e., computing) circuits. From a noise and distortion perspective, are they OK for audio? Thank you for your thoughts, Jacques |
#2 |
Be aware that high-K dielectrics like Y5V and Z5U exhibit large changes of capacitance with changes of voltage and temperature.
I have a Mini-ITX based PC, which uses X5R dielectric capacitors as the output dc blocking caps on the built-in sound card. Distortion at high audio frequencies is low but the capacitors cause very considerable distortion on low-frequency signals. |
#3 |
Large value SMT ceramics are also the most problematic when it comes to soldering... especially hand soldering... the big guys (over 0.1 uF) are fragile.
| SMT capacitors for audio | Markus2006 | Parts | 4 | 1st October 2008 01:37 PM |
| capacitors for car audio | cyclone-audio | Car Audio | 8 | 8th June 2006 01:35 PM |
| Best capacitors for Audio?... | VS | Pass Labs | 15 | 9th January 2005 02:08 AM |
| Audio Capacitors | RichH | Solid State | 2 | 11th March 2001 08:22 AM |
| Page generated in 0.06157 seconds (72.44% PHP - 27.56% MySQL) with 10 queries |
