Old 28th June 2006, 08:16 AM   #1
ben goh is offline ben goh  Singapore
Send a message via AIM to ben goh Send a message via Yahoo to ben goh
Default Bat Vk200
Hi
Have a faulty channel on the VK-200. Smoke up on left channel
Have replaced both rectifiers, link broken pcb tracks and it still blow both fuses.
Any infor or schematic to guide?
Appreciate for any help.
Old 29th June 2006, 02:06 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Then you should check for shorted semiconductors.
Old 29th June 2006, 02:26 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi ben goh,
Do you have a variable DC supply or a variac? You need to apply power slowly so you do not extend the damage. With a little power you can measure where the excess current is flowing before things go bang.
-Chris
Old 29th June 2006, 03:02 AM   #4
lgreen is offline lgreen  United States
lgreen's Avatar
I have one (well just sold it), the semi's are not accessible.
Too bad.
Perhaps email victor (the president); or post on audioasylum.com; he is the designer and has responded to my prior emails within a day or so.
My DIY audio projects- PartTimeProjects.com.
Old 29th June 2006, 03:04 AM   #5
Hi, thanks for the reply.
I have checked all the driver and output mosfets and they are
good. The fuses will give way only when the relay clicks. I don't
understand the function of the relay ( not for output ) and the
main reservoirs cap are not grounded. It a rather tough design.
Old 29th June 2006, 07:17 AM   #6
Hi Igreen
I wrote to BAT for help.
Nobody bothers to reply me.
There is no local agent here
Old 29th June 2006, 12:32 PM   #7
anatech's Avatar
Hi ben goh,
Disconnect any load you may have on the outputs of the amp.
lgreen,
How did you like your amp?
-Chris
Old 29th June 2006, 01:50 PM   #8
Hi Anatech
No load attached
Still blow fuses, suspect PCB problem
Old 29th June 2006, 02:21 PM   #9
anatech's Avatar
Hi ben goh,
I wonder if the bias is disabled until a timeout period has ended. Only one other thing I've seen can cause this. I found a relay with one contact shorted to the coil once.
-Chris
Old 29th June 2006, 04:52 PM   #10
diyAudio Moderator Emeritus
Hi, Ben Goh,
Are you the FM Acoustic/Naim dealer in Singapore?
Page generated in 0.08896 seconds (78.90% PHP - 21.10% MySQL) with 9 queries
