Old 26th June 2006, 08:10 PM   #1
Did it Himself
richie00boy's Avatar
Default Ever made a MOSFET CFP/Sziklai that works?
I built an amp with CFP output stage using IRF540N and IRF9540N devices with TIP29C and TIP30C drivers. The upper CFP bursts into oscillation after a short random time after power-up 9/10 times.
I thought I had cracked the design of this amp, just looking if anybody has successfully made a MOSFET CFP/Sziklai, I know Millwood (long time gone) was having problems as well.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 26th June 2006, 08:26 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Yes, but a "long" time ago, also using irf540n/9540n.
I used bd139/140 as driver for the first one, and mje243/253 for the 2nd one. I had 10pF CB-caps at the drivers.
It sounded very powerful... But i had bias problems and didn't follow further.
Mike
Old 27th June 2006, 10:15 AM   #3
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Hi Richieboy,
I have designed complemantary mosfet amp with sizklai pair, but it requires some modification though....
1. 220 ohm resistors at the base of driver transistors,
2. R_collector=220ohms and R_emitter=47ohms
3. Rsource=0.47ohms 3Watts
4. 22pF at C-B of drivers
5. UF4004 diodes at C-B of Drivers...
6. Mosfets=IRF540/9540N
7. Drivers MJE340/350
8. Rgate=100ohms+IN4148
9. Gate to Source 7.5V 1W Zeners
Hope this Helps...
K a n w a r
Old 27th June 2006, 10:22 AM   #4
Did it Himself
Thanks Kanwar, I had already implemented a most of what you suggest even with very similar values. A few things to try though, like driver base resistors and driver C-B caps and diodes.
How do the driver C-B diodes help?
I see you have an antiparallel diode on the gate resistor to help with cross-conduction - a good mod I will add if it gets past the not oscillating stage.
Old 27th June 2006, 10:29 AM   #5
Workhorse's Avatar
Hi Richieboy,
The C-B Diodes helps very much by facilitating fast recovery from clipping behaviour when the VAS drives the Driver stage much harder....
I haven't experience any thermal biasing problems nor any of the oscillations.....so far!
regards
K a n w a r
Old 27th June 2006, 11:20 PM   #6
Fanuc is offline Fanuc  United Kingdom
Have never seen it done reliably with DMOS/hexfets/vertical based mosfets to be honest - or amp designers advocating it.
Seen it done with lateral power mosfets but I get the feeling some DMOS fets are faster in common source mode than lateral's in source follower mode.
An IRF240 has a GBP above 100mhz and transit times of 1ns or under etc.
I would stick with laterals with a high gain video transistor grade driver. Sanyo's 2SC2911(T) and it's comp. springs to mind. Very linear device.
Old 7th August 2006, 05:30 AM   #7
Workhorse's Avatar
Hi Richie,
Have you successfully mentored the CFP amp, please do post your results , So that every one could benefit from it....
regards,
K a n w a r
Old 7th August 2006, 07:41 AM   #8
is SKA by Ampguru a Sziklai connected FET?
regards Andrew T.
Old 7th August 2006, 09:22 AM   #9
Did it Himself
Thanks for the reminder Kanwar. I made some mods to the amp but have not yet tested due to some other things taking priority. I will keep this thread updated
Old 7th August 2006, 10:13 AM   #10
forr is offline forr  France
forr's Avatar
John Linsley-Hood and Doug Self have proposed bipolar input - Hitachi mosfet output Sziklai pairs for output stages. I once built the JLH circuit, no stability problem at all.
a wonderfull sziklai sakis Solid State 203 18th May 2012 11:25 AM
Sziklai output Moby Solid State 68 27th January 2011 10:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 10:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 06:39 AM
Negative Sziklai timH Solid State 17 30th July 2007 10:13 PM
Page generated in 0.10169 seconds (80.46% PHP - 19.54% MySQL) with 11 queries
