Ever made a MOSFET CFP/Sziklai that works? - Page 2 - diyAudio
Old 8th August 2006, 07:34 AM   #11
Workhorse's Avatar
Originally posted by AndrewT
is SKA by Ampguru a Sziklai connected FET?
Hi AndrewT,
The SKA is not a CFP or a SIZIKLAI type....Its simply behaves like a Common Source amplifier at its output...
K a n w a r
Old 11th August 2006, 11:59 PM   #12
ingrast is offline ingrast  Uruguay
Default Working MOS CFP IRF530/9530
Just came across this thread, think I may contribute a bit.
Attached is schematics of working MOS IRF530/9530 output stage, it may look complex but could not figure out a simpler approach to biasing control *and* gate capacitance issues at crossover. This design ensures both devices are allways conducting.
I had to remove some details since part of this amplifier is under patent registration process. Measured performance is comfortably below 0.001% THD.
Posted below is a photo of an assembled amplifier module.
Rodolfo
Old 12th August 2006, 12:00 AM   #13
Default Schematics
Don't figure what went wrong, here is the schematics.
Old 12th August 2006, 12:08 AM   #14
Default Module
Here is one assembled module.
Currently there are 8 amplifiers working inside 4 biamped boxes, though the first 4 were earlier iterations. In all they have probably now over 400 hs. with no problems so far. Sound great for me but this is a biased opinion, others agree too.
Rodolfo
Old 12th August 2006, 06:10 AM   #15
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Rodolfo,
Very intersting . Is it "current mirror with gain" like Blomley?
What is the bias of the output transistors, how many mA or A?
The signal input is 1 path, from the junction of R12-R13? How do you set the bias?
Old 12th August 2006, 12:52 PM   #16
Lumanaw:
Measured stand by current is about 80 mA. Simulations do not work very well I suspect beacuse of poor device modeling. Analytical solutions I found far too messy even with simplifying assumptions so I pushed them to later stages.
Anyway, it is not difficult to gather conceptual criteria for design. basically bias current is established for example for the upper half, by the ratio of T7 emitter resistor (R23) to T2 source resistor (R31) and by T7 emitter current. The circuit tries to equal voltage drop across both.
T7 emitter current in turn is set by R25 (T6 is normaly cut off, works for overload protection) and by T3 driver standby current.
Input is at the junction of R12 - R13 as you found.
Rodolfo
Old 12th August 2006, 05:48 PM   #17
Did it Himself
richie00boy's Avatar
Thanks for the schematic, I will study it.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 12th August 2006, 08:19 PM   #18
lumanauw:
" Is it "current mirror with gain" like Blomley?"
hello lumanauw,
no, itīs more like Hegglun (EW1995)
Heinz!
Old 12th August 2006, 10:43 PM   #19
Originally posted by powerbecker
...no, itīs more like Hegglun (EW1995)
Heinz!
Interesting Heinz, I was not aware of this design. I notice there is no resistor in T3 (T7) emitter, so stand by current is not very well defined except perhaps - must study further - by T2 (T8).
There is no overcurrent protection provision either, but it is acceptable for a concept prototype.
Rodolfo
Old 13th August 2006, 01:00 AM   #20
djk is offline djk
djk's Avatar
There is another even earlier example of your bias scheme in Wireless World, I don't have a scanner hooked up though.
I built an amp like this (without your current limiting) in 1997. You have omitted a couple of caps for clarity I assume.
Rockford Fosgate sold CFP HexFet amps over 20 years ago. Their biggest at that time was 500W/ch. They used an ordinary bias circuit and a 5532 for the front end. Their 100W/ch unit was a huge seller.
a wonderfull sziklai east electronics Solid State 266 27th November 2012 02:34 PM
Sziklai output Moby Solid State 68 27th January 2011 10:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 10:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 06:39 AM
Negative Sziklai timH Solid State 17 30th July 2007 10:13 PM
Copyright Đ1999-2017 diyAudio
