Hi all,I've been given a Realistic chassis which has been stripped.It used to be a reciever,but all that has been gutted and all thats left is the amp board and psu.It was used as a bridged amp for a sub.The bridge was a basic op-amp affair which has been removed.The amp worked fine for a while then justwent wrong.I put an old loudspeaker on it and the cone sucked in."Ooops",DC on the output.I replaced the speaker for me meter and on both channels it reads 40vdc.Nothing cooks,the relay doesn't cut out and I can't for the life of me know whats wrong.I did an ohms check to see if any of the output trannies are short,but they're ok.I have two IC's with heatsink tabs on them and assume they either are drivers or biasing circuits and I'm not sure how to check them.
Does anyone have a clue? STA-2270 Digital Synthesized AM FM Reciever. Cheers.Mikee55 |
#2 | |
/Hugo |
#3 |
Did it Himself
Both channels have the same DC output? Then the same fault is on both. When you removed the op-amp bridge adapter, maybe you connected the inputs back up wrong?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Hi thankyou for replying.The fault occured with the bridge circuit attached.Thats why I now have the amp.I removed the bridge circuit to see if this made a difference.Thing is my JVC AX-2 went to heaven,and my Technics SU-V2has only one channel and until I build my gain clone Im stuck using the guts from a pair of PC speakers as an amp.I have 7watts per channel to play with.I understand this Radioshag has 75watts.
I wouldn't mind a burnt unit,but this thing looks innocent,nothing visual,I would have thought 40 volts output would give a burnt component or heat,smoke but not a thing.Didn't even blow its fuse. Doh[/B] Ah well,worth the try I suppose cheers
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi |
#5 |
You you say it has 40 volts on the output? do you have the -40V on the other set of output's? if not, thats your problem. the other is a bad driver(s) or a part in the pre-amp thats gone and of course being DC coupled you get a good DC output.
#6 |
Is it 40V on one output or both?
If it's both, check the -40V hasn't gone missing. Don't bin the chassis - use it for your gainclone |
#7 |
Hi all,not been well today,will check voltage again tommorrow and I'll get back to you.
Kind regards Mike
#8 |
Hi,better today.I've taken some readings and I get + 40vdc on both channels,and I've measured the psu at the smoothies and it seems to be fine +/- appx 42vdc.I'm using an analogue meter at the mo,my DMM needs a new battery.
The voltage out of the speaker terminals is +40vdc as in the red terminal is + , there is no negative as the black terminal is ground at 0v.Does this make any sense? So,Relay operates when its switched on,power supply is ok,output trannies ok and pure DC on the LS terminals,relay should shut the amp down shouldn't it?By the way the longest period I've left it on is less than a minute and I just connected the meter leads to the LS terminals without a load added! Thanks Mike
#9 |
Output trannies short = blowing fuses or lots of smoke. Possibly the one of the output trannies is open ? Worth checking, should measure as a pair of back to back diodes. (unless its a FET output stage) |
#10 |
The upc1225H seems to be a 30 to 50 watt power amp driver.God knows how to test these!?
| FS - (4) 36,000uf/40VDC caps | Guiness | Swap Meet | 1 | 19th February 2008 03:56 AM |
| 2 x Sprague 20,000 MF 40Vdc Caps | jeffshort2000 | Swap Meet | 1 | 30th November 2007 02:22 AM |
| BHC 33000µF/ 40Vdc | WALTER BURKHARD | Swap Meet | 0 | 31st January 2004 09:48 PM |
| I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output | iklari14 | Digital Source | 30 | 18th July 2003 12:57 PM |
| 36kuf @ 40VDC PSU Capacitors for Sale, NOS | roddyama | Swap Meet | 7 | 27th May 2003 04:42 AM |
| Page generated in 0.11280 seconds (73.79% PHP - 26.21% MySQL) with 11 queries |
