Amp with 40vdc on lts output - Page 2 - diyAudio
Old 27th June 2006, 09:08 PM   #11
uPC1225H is indeed the frontend for an amp, encompassing the LTP, VAS and driver stages. To be honest that's going to make it pretty much impossible to repair without swapping out the chip, and these things will be well obsolete.
The best you can do here is check that the output stage hasn't failed open, as already suggested. If the output transistors are OK, I would say gut the chassis and use the transformer, psu caps and possibly the output transistors (if they are OK and decent) and build the P3A amplifier.
uPC1237H is a fairly well known amplifier protection circuit IC. It was quite commonly used, but it wouldn't cause the fault you're describing.
Old 27th June 2006, 10:18 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Mike,
Both channels at +40VDC. Did you check that the input is referenced to ground?
-Chris
Old 27th June 2006, 10:35 PM   #13
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default input referenced to ground
Hi,not sure if input is referenced to ground.I think I should abort and strip it and look at the P3A amp to see if I could build that.
A big thankyou to everyone who replied.This amp's issue is going way over my head.As is my PC who doesn't want to turn my kids DVDs into Divx files to be stored on my network so they can stream it on their PC's.Anyway,thankyou kindly.Ill be back soon.
Bye for now. Mike Love and Peace to you
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 27th June 2006, 10:46 PM   #14
anatech's Avatar
Hi Mike,
Don't bail yet! It sounds like there may be a simple fault.
Stick with it and solve the issue, otherwise you won't learn anything.
-Chris
FS - (4) 36,000uf/40VDC caps Guiness Swap Meet 1 19th February 2008 03:56 AM
2 x Sprague 20,000 MF 40Vdc Caps jeffshort2000 Swap Meet 1 30th November 2007 02:22 AM
BHC 33000F/ 40Vdc WALTER BURKHARD Swap Meet 0 31st January 2004 09:48 PM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
36kuf @ 40VDC PSU Capacitors for Sale, NOS roddyama Swap Meet 7 27th May 2003 04:42 AM
Copyright 1999-2017 diyAudio
