my new amp (comments?)
Old 1st December 2002, 09:54 PM   #1
LennyK is offline LennyK  Poland
LennyK's Avatar
Question my new amp (comments?)
hi
I'm new here . It's my first post .
I want to build amp for my bass unit (bi amp with push-pull ultralinear EL34 for treble/mid). It will have 100-150W. I post schematic (sorry for quality). Any comments, new ideas? (don't laugh to loud ).
It look like amp form Elektor (autor Giesberts). I made only few changes (especially in the input stage).
"Pre" section will have regulated voltage.
Bias maybe about 200mA
I think about 4 things:
-2 amps/channel (XLR inputs, balanced) would be nice ?
-2, not 4 transistors/channel (especially when balanced)
-different type of output stage (next post)
-different type of driver stage (cascode with constant power, like input stage)
Lenny
Old 1st December 2002, 09:56 PM   #2
LennyK's Avatar
Default different output stage
I know that output voltage swing will lover with this wersion, but with BTL and separate PSU for "pre" that is no problem.
Old 1st December 2002, 10:05 PM   #3
halojoy is offline halojoy  Sweden
On Hiatus
Thumbs up Nice schematics!
I wish I could get such quality
in my schematic pictures.
Old 1st December 2002, 10:45 PM   #4
Jeff R is offline Jeff R  United States
I just took a quick look, so I may be in error, but a couple of things I have noted:
1. Your use of AC coupling on the input but not the output. Why not use a fully DC coupled design?
2. I see only a pure resistive feedback network. You should use a capacitor to roll off the high frequency response.
3. You might also wish to use a capacitor in the main feedback loop to reduce the DC gain to 1 (highly recommended in DC coupled amplifiers).
4. Your driving the FETs from a common emitter configuration seems like a bad way to go. I would recommend driving them from emitter followers - with 150 collector resistance like you have, I would think the transient performance would be poor.
Hope this helps.
Jeff R.
Old 1st December 2002, 10:57 PM   #5
On Hiatus
In a current feedback amplifier
you do not use the usually frequency filter capacitor
in the global feedback
It is done somewhere else,
but where?
This one uses the emittors of transistors as the feedback
input (the inverted input)
DC input I use when I want DC outputs.
Like when playing AC/DC.
I use caps,
mainly because my speakers have so bad
response for frequencies BELOW 20 Hz
I know I miss that part of the music
But what can you do what such bad speakers?
Old 1st December 2002, 11:02 PM   #6
Christer is offline Christer  Sweden
Just a minor additional comment. All three JFETs could be
replaced with resistors.
Old 2nd December 2002, 12:56 AM   #7
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Default Re: Nice schematics!
Looks like it was done with Protel for Windows that came out in the early 90's. I have one that they outgrew at work.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 2nd December 2002, 09:53 AM   #8
LennyK's Avatar
Thank you for comments.
Yes, that's Protel Protel SE form their www page (trial version ).
I forgot to mention that DC offset wil be done with DC Servo, so maybe this capacitor in input is realy bad idea.
Hi frequency behaviour is depended on C7, C8. I hope this is enough. Correct me if I'm wrong. I'm litle worry about oscilations, because I don't have osciloscope.
Old 2nd December 2002, 11:06 AM   #9
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Lenny if you want to study the concept of current feedback, check ON and National.
http://www.national.com/search/searc...ack&full=1#App
Have some trouble to find at ON but I know they have good documents.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 2nd December 2002, 12:47 PM   #10
hugonot is offline hugonot
Default Ohmmm....
Meybe you could change first&second stages to one j-fet stage.
You could take a voltage gain and very good input bufer ( it have really high input imedance ). It is a possibility to connetc NFB with the current mode.
There is a great amount of negative feedback in last two stages, I,m affraid it could oscilate.
You have to design a system to prevent volage peaks, because Hexfets could burn to death. Maybe a capacitor across bias stabiliser, meybe zener diodes or system that slowly raises PSU voltages.
Dobra Lenny pogadamy na Aikido.
my new amp (comments?)Hide this!Advertise here!
psu comments! lanchile07 Chip Amps 15 27th August 2008 12:20 AM
Comments please on this I/V amp georgehifi Digital Source 9 11th April 2008 02:12 PM
X-over Comments & Help GOWA Multi-Way 23 20th March 2008 01:09 AM
Would appreciate comments... TonyDasilva Digital Source 2 11th August 2005 06:50 PM
Comments on 71a PP Pre-amp RichardJones Tubes / Valves 33 11th April 2003 08:22 PM
