my new amp (comments?)
Old 2nd December 2002, 02:04 PM   #11
halojoy is offline halojoy  Sweden
On Hiatus
Originally posted by hugonot
There is a great amount of negative feedback in last two stages, I,m affraid it could oscilate.
Dobra Lenny pogadamy na Aikido.
I have seen small capacitor
across R27, 33 ohm
in this type of output stage with a voltage gain
Also is good, maybe nessesary,
with a separate Power Supply for the output stage
for Current Feedback Amps.
They are more sensitive for such feedback.
This is already done here.
DC-servo. Why?
Nelson said somewhere that he can tolerate some 0.500 volt.
How much watt is that?
Would it ruin your speaker?
I know that I would give such a speaker away to charity
or better to destruction!
You will get far, far less DC-offset than 0.500 volt,
if you trim your amplifier.
Isn't it better to use some delay and a relay,
until DC-offset settles?
Old 11th December 2002, 02:37 AM   #12
mikek is offline mikek
Account Disabled
Originally posted by peranders
Lenny if you want to study the concept of current feedback, check ON and National.
http://www.national.com/search/searc...ack&full=1#App
Have some trouble to find at ON but I know they have good documents.
check out www.ti.com also
Old 11th December 2002, 04:07 AM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Only as a short term proposition (warming up). 100 mV is
my acceptable limit for most speakers, and I like a lot less
than that.
BTW, 0.500 V is 1/16 watt into 8 ohms.
Old 11th December 2002, 04:11 AM   #14
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
my new amp (comments?) Send a message via AIM to Peter Daniel
When I turn on my A75, DC offset is 300mV or so and starts slowly going down to approx. 20mV after 20min. if I remember correctly.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th December 2002, 06:20 AM   #15
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
My 50w class A has 325mv offset all the time. Is the dc drop across the output choke @ 3.5 amps. Would be nice if it didn't but I don't think it has any real detriment to the sound, especially if you don't know about it. That last bit sounds funny but I think it has quite some truth to it.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 11th December 2002, 07:31 AM   #16
phase_accurate is offline phase_accurate
Hi Lenny
I once performed simulations on a circuit that was a little similar to yours.
The main difference is that mine is inverting and it's input stage is a little simpler than yours. The simulation results looked promising.
http://www.diyaudio.com/forums/showt...?threadid=7058
I particularly like the output stage on your first schematic. The first reason (as you already mentioned) is that it can be driven very close to the rails. The second reason is that lower Vce driver transistors can be used.
I don't think that this is topology is very critical regarding stability.
I haven't found the time to try my circuit out so far but a workmate of mine is very curious about it's performance and will most probably try it out.
Good luck with yours
Charles
Old 11th December 2002, 05:05 PM   #17
On Hiatus
Default we share diy-listen with friends/family
Originally posted by phase_accurate
Hi Lenny
Charles
in't it nice we can give "sound advices"
to anyone person surrounding us
i do it a lot - specialy my eldest brother asks me many advices about his soundsystem
- i have designed, my own, hifi headph-amp
custom made to suit his headphones - he bought model after advice given (Sennheiser 600)
watch me know - i am the american dream
some links on amplification design tubes/transistors at
Music&Mp3 Page of Groman the Swede
my new amp (comments?)Hide this!Advertise here!
psu comments! lanchile07 Chip Amps 15 27th August 2008 01:20 AM
Comments please on this I/V amp georgehifi Digital Source 9 11th April 2008 03:12 PM
X-over Comments & Help GOWA Multi-Way 23 20th March 2008 02:09 AM
Would appreciate comments... TonyDasilva Digital Source 2 11th August 2005 07:50 PM
Comments on 71a PP Pre-amp RichardJones Tubes / Valves 33 11th April 2003 09:22 PM
Copyright ©1999-2017 diyAudio
