does anybody have the (P)SPICE models for the power mosfets BUZ900/901 and BUZ905/906 ? Thanks
Teodoro |
#2 |
According to Charles Hanssen in an earlier thread both Magnatec and Exicon use exactly the same Semelab chips in their lateral MOSFETs, so the Exicon models should work fine.
http://www.diyaudio.com/forums/showt...238#post171238 |
#3 |
Here they are.
(I got the models directly from Magnatec). .SUBCKT BUZ901D 1 2 3 * MODEL FORMAT: SPICE Level 1 * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=0.001 W=0.001 * Default values used in M: * The capacitances are added externally * Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM NMOS LEVEL=1 IS=1e-32 +VTO=0.362 LAMBDA=0.06 KP=3.097 RS 8 3 0.178 D1 8 9 MD .MODEL MD D IS=1.0e-32 N=50 BV=250 +CJO=1.77e-9 VJ=0.1 M=0.28 RDS 8 9 1e+06 RD 9 1 0.265 RG 2 7 42 * Gate Source capacitance Cgs0 CAP1 7 8 900e-12 ************************* * Gate Drain capacitance Cdg0 CAP 7 4 18.7e-12 ************************* * Gate Drain Capacitance Cdgj0 * Modelled as a diode D2 4 9 MDD .MODEL MDD D IS=1e-32 N=50 +CJO=75e-12 VJ=0.1 M=0.768 ************************* .ENDS BUZ901D .SUBCKT BUZ901P 1 2 3 * MODEL FORMAT: SPICE Level 1 * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=0.001 W=0.001 * Default values used in M: * The capacitances are added externally * Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM NMOS LEVEL=1 IS=1e-32 +VTO=0.473 LAMBDA=0.092 KP=1.585 RS 8 3 0.41 D1 8 9 MD .MODEL MD D IS=1.0e-32 N=50 BV=250 +CJO=1.0e-9 VJ=0.7 M=0.5 RDS 8 9 1e+06 RD 9 1 0.58 RG 2 7 80 * Gate Source capacitance Cgs0 CAP1 7 8 400e-12 ************************* * Gate Drain capacitance Cdg0 CAP 7 4 10.5e-12 ************************* * Gate Drain Capacitance Cdgj0 * Modelled as a diode D2 4 9 MDD .MODEL MDD D IS=1e-32 N=50 +CJO=94.8e-12 VJ=0.3 M=1 ************************* .ENDS BUZ901P .SUBCKT BUZ906d 1 2 3 * MODEL FORMAT: SPICE Level 1 * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=0.001 W=0.001 * Default values used in M: * The capacitances are added externally * Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM PMOS LEVEL=1 IS=1e-32 +VTO=-0.273 LAMBDA=0.5 KP=0.548 RS 8 3 0.171 D1 9 8 MD .MODEL MD D IS=1.0e-32 N=50 BV=250 +CJO=1e-9 VJ=0.7 M=0.5 RDS 8 9 1e+06 RD 9 1 0.259 RG 2 7 45 * Gate Source capacitance Cgs0 CAP1 7 8 1.08e-9 ************************* * Gate Drain capacitance Cdg0 CAP 7 4 36e-12 ************************* * Gate Drain Capacitance Cdgj0 * Modelled as double diode D2 9 10 MDD D3 4 10 MDD .MODEL MDD D IS=1e-32 N=50 +CJO=762e-12 VJ=0.1 M=1 ************************* .ENDS BUZ906d .SUBCKT BUZ906P 1 2 3 * MODEL FORMAT: SPICE Level 1 * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=0.001 W=0.001 * Default values used in M: * The capacitances are added externally * Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM PMOS LEVEL=1 IS=1e-32 +VTO=-0.426 LAMBDA=0.073 KP=0.673 RS 8 3 0.342 D1 9 8 MD .MODEL MD D IS=1.0e-32 N=50 BV=250 +CJO=1.45e-9 VJ=0.446 M=0.377 RDS 8 9 1e+06 RD 9 1 0.523 RG 2 7 45.2 * Gate Source capacitance Cgs0 CAP1 7 8 696e-12 ************************* * Gate Drain capacitance Cdg0 CAP 7 4 15.2e-12 ************************* * Gate Drain Capacitance Cdgj0 * Modelled as a diode D2 9 4 MDD .MODEL MDD D IS=1e-32 N=50 +CJO=27.6e-12 VJ=0.817 M=0.871 ************************* .ENDS BUZ906P |
#4 |
... however I'm getting crazy in trying to make it work in Cadence ORCad PSPICE. I'm not really an expert of (P)SPICE.
Could you please give me some little help ? Thank you
Teodoro |
#5 |
I don't know that particular version of Spice, but please not that the models are subcircuit models, not standard MOSFET models. I don't know what implications that has in your version of Spice, but if you search the forum there shoudl at least be info on how to use them in LTSpice, which may or may not help you.
#6 |
Those particular subcircuits are the ones I used with TINA and they compiled and ran perfectly. Be warned that there can be a very large device-to-device variation on BUZ90x devices (see the variation in threshold voltage shown on the data sheet) and these subcircuits don't accurately model this.
#7 | |
More precisely, when using subcircuits, it may be possible to vary some, but not most, parameters if using DC sweep analysis. But that is anyway only useful for Q points and similar. |
#8 |
I succeeded in using the models you provided in PSPICE.
Thanks to all !
Teodoro |
| spice models for led | fscarpa58 | Parts | 18 | 10th August 2009 10:16 PM |
| Spice models | stinius | Solid State | 0 | 18th November 2008 09:07 PM |
| spice models | Zoran | Solid State | 11 | 17th September 2005 02:03 PM |
| Spice Models | ACR | Solid State | 4 | 13th September 2003 04:59 PM |
| Spice models | JoeBob | Solid State | 18 | 25th April 2002 02:34 PM |
| Page generated in 0.11361 seconds (79.88% PHP - 20.12% MySQL) with 10 queries |
