I'm putting together the cases for my p3a and p88 amp and preamp and was wondering what people do to put lettering on the front panel. Normally on store bought equipment all the lettering is silk screen printed but obviously that's not possible for 99% of diy'rs. What are people doing or are they just leaving the panels unprinted.
#2 |
I'm using dry transfer sheets under Letraset brand name. You can purchase it from graphic supply stores.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
These are yet untried ideas, but I have been thinking about
alternatives to silksccreen using photoresist of the type used for etching PCBs. One would then make a mask such that the photoresist covers all but the text/symbols. Then one might simply paint over the whole plate. This requires finding some suitable paint that sticks well to metal but that doesn't stick to the photoresist, or at least is thin enough so it will separate nicely where we want it to while removing the photoresist. An alternative way would be to actually etch the plate to get pits where we want the text. Then we could remove the photoresist and then paint the plate. Then we could simply rub off the paint and, hopefully, it will remain in the pits. I think acrylic paint should be quite suitable here. It is easy to rub off from metal, but if we use it thin enough it should stay in the pits. The painting process may be repeated to get a thicker layer in the pits. If desired, we may finish off with some suitable transparent treatment, eg. acrylic varnish. There might be better choices of paint for metal, perhaps. An obvious advantage of these methods over readymade things like letraset is that it would be quite easy to use multiple colours. These are just some ideas I have been playing aound with. I am not in the phase where I need to do this myself for some time to come, so test pilots are welcome if you think this might be worth a try. |
#4 |
I have been experimenting with decal paper and aluminum. The decal paper is the clear plastic decal material used in model railroading. You print your lettering or artwork on the paper using an inkjet printer (or laser, but the results are worse). Then you cut the decal, soak it in water, and apply it to the metal. The decal dries onto the metal. You can fix the decal by painting a clear coat over everything.
So far I just tried with some scrap, but the result are first rate. |
#5 |
Jwb,
If I understand you correctly, you cut a sheet the size of the whole metal plate? I have been thinking about similar things but the problem is that I will most likely want white text on black metal, which would require a printer that can actually print white paint. Such printers would be most rare, if they exist at all. I got a new idea, though. I have also been thinking about using a plastic sheet as a stencil to apply the paint to the metal plate. That would require making holes in the sheet corresponding to the text, and cutting such holes is hardly tempting. However, if one could find some suitable chemical to etch holes in plastic, then one could use the photoresist method on a plastic sheet, etch it and then use this sheet as a stencil. Perhaps it would be better to use a thin sheet of some metal. That might be easier to etch sharply. Further ideas/opinions on this is welcome. |
#6 |
You can use nothing but the photoresist itself to get lettering on light metal surfaces, however, you will only have one colour available and the quality isn't THAT good.
Just spray the photoresistant on the whole frontplate, put your (positive) film on it, light, develop... done. One advantage is that you can make letters and symbols in any sizes your printer can print. It's also good for small series. To make it more sratch resistant, you can burn it in by putting it in your oven for some hours. This changes the colour a little bit. I've done it that way on some of my PA electronics in 19" cases, but I wouldn't like it on my home high end equipment. In Germany, there's a company that makes your very own frontplate with high quality lettering in every colour you could imagine. They provide you a design software to download and you send them the file. They also drill holes and everything. Somewhat pricey however... |
#7 |
If you use black anodized aluminium, you can cover the whole plate with photoresist, then expose with a photographic film, and use normal revelator as for PCB.
If you then etch the plate with light nitric acide solution, you can obtain white letters. But it is essential to not use soda or sodium carbonate to remove the photoresist, because soda will etch the black aluminium oxide layer. Use acetone instead. Warning : nitric acide is dangerous, use suitable glasses and gloves, don't inhale vapors. Nitric acide will etch all metals. Mix with plenty of water before throw away. Acetone is very inflammable, don't smoke or use electrical appliance. Acetone fire can be extinguished with water. Regards, Pierre Lacombe. |
#8 |
If you can make your own PCB's you can silk screen -- it's the same idea. You coat the surface with a photographic emulsion, expose, develop etc. But oh ! the investment of time and money !
Here's my method -- I use Power Point to set up a slide with the panel -- you can add text, text art. boxes, circles, rectangles, fill with color etc. I print to an Avery Full Page Label -- Avery 8665 -- it's a lot easier than decals. (These are the same full page labels I use for PCB's). Seems that the electronics of what we do for a hobby is the least of the expense. Getting it into the box and making it look nice chews up a lot of money! |
#9 |
Here's the sample of dry transfer on my BOZ. It was done in '96 and there is no sign of wear and tear. No coating done.
#10 |
Your projects always look great Peter! I think your method is the fastest and easiest, I'll try to find the letraset dry transfers somewhere. They seem similar to what plastic modelers use, with the differance being that in modeling you apply a special coating after applying the decals to get them to snug down to every groove and crack.
| Front Panel / Enclosure Help | tumler | Parts | 8 | 7th August 2007 08:41 AM |
| Lettering on transparent panel | GRollins | Everything Else | 42 | 4th February 2007 03:19 PM |
| DIY Front Panel !! | udip | Solid State | 12 | 16th January 2005 06:37 AM |
| Aluminium for front panel | jouch | Solid State | 7 | 15th March 2001 10:51 PM |
| Page generated in 0.14851 seconds (77.16% PHP - 22.84% MySQL) with 11 queries |
