High end diy amps schematics
Old 21st June 2006, 06:59 PM   #1
tcl2 is offline tcl2  France
Default High end diy amps schematics
Hello
Could someone indicate me diy links for amps having a commercial
equivalent of about 2,000 or 3,000 dollars?
For instance, is it possible to find a Jeff Rowland like amp schematic(or some other trade mark) being of the same quality but not of the same price...
Thank you
Old 21st June 2006, 07:07 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
If you search, you will find better amps on this site than any of those overpriced famous brands. Oh, and there might well be the odd schematic as well.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 5th July 2006, 09:07 PM   #3
=maximum= is offline =maximum=  Italy
Hello! an interesting design is the Power Follower 99, similiar to pathos amps....the designer's Andrea ciuffoli have a website: www.audiodesignguide.com ... if you couldn't find the schematics write me and I can mail you the copy of the schematics appeared in the Italian DIY magazine "costruire HI-FI" ... ;-)
Old 6th July 2006, 04:41 AM   #4
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
The power follower was the first Class A amp that I built. It is only ok in my book and its output is capacitively coupled so there is that problem too... but its a good beginners amp to build. When you shop for heat sinks decide on what you want and then double that size and you might have enough. For that size amp it runs really, really hot!
Mark
KSA-100 WIKI
Old 7th July 2006, 04:12 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Hi,tcl2 www.passdiy.com
Old 7th July 2006, 08:51 AM   #6
Hello! yes the output stage is decoupled By a 4700 uF capacitor to block the DC....but you must consider thath most of the design with no output capacitors have a double power supply (in this case tha amp work with a single power supply...) so the capacitors on the signal path remain two....
I have buildt other class A amp (this one is no the best but not so bad... ;-) )...
I post the schematic...
Old 7th July 2006, 05:27 PM   #7
forr is offline forr  France
forr's Avatar
--- most of the design with no output capacitors have a double power supply (in this case tha amp work with a single power supply...) so the capacitors on the signal path remain two....---
This kind of amps can deliver DC, so their power supply cannot be considered in the signal path. If it were, the caps would limit the low frequencies response.
High end diy amps schematicsHide this!Advertise here!
schematics for older RF amps 17DoubleE Car Audio 9 2nd September 2010 07:05 AM
Schematics for Bedini Amps Models 802 or 803 bighume Solid State 0 31st May 2008 09:25 AM
Simple fet amps schematics, suggestions? nikwal Solid State 0 3rd December 2006 10:51 AM
I coined the phrase HIGH VIVIDITY, to differentiate our amps from High Fidelity ones vax9000 Tubes / Valves 8 31st October 2006 02:10 AM
working schematics for class d amps steven344 Class D 0 21st November 2005 07:36 PM
