Quad 405 Mk 1
Quad 405 Mk 1
Old 23rd June 2006, 06:32 PM   #11
Current Dumper is offline Current Dumper  Netherlands
I'am in the process of revising the 405-1 schamatic with all Ludwig and Snook's modifications. I can post it here if you like
Old 24th June 2006, 09:30 PM   #12
bulgin is offline bulgin  South Africa
Default Quad 405
Hello All & Current Dumper
My congratulations (and amusement!) at your original choice for a 'rack mount handle' here at diyaudio.com -clap, clap and a hearty Heheeheee!
If you could find the time, I would appreciate very much a posting of this schematic as the Quad impressed me until now and I'm trying to find a little space to fit it somewhere to be permanently hooked up.
I visited a friend today and found a little orange and gold tuner tuned to some jazz this afternoon. Anyway, he told me about another 405/44 setup for sale locally (Cape Town) for the equivalent of UKP450.- , far too much.
At the moment, I'm running it with a Kenwood Basic CI pre, which is my little workhorse (also using it with my Leak Stereo 20) and this partnership sounds really good.
Thanks for your kind offer.
Nice weekend to all
bulgin
Old 25th June 2006, 04:35 PM   #13
Default Quad 405 MK 1 - MAINS AC ON/OFF
Hi Wise Men
I've hooked-up the Quad on my overpopulated equipment rack which is parked against a wall. It had to go in sideways, next to my Leak Stereo 20 and the mains lead goes to an ac 220V socket extender, where all my other things are also plugged-in. This extender powers whatever amp I'm using, plus the pre-amp, and is also hidden in an inaccessible place.
The ac socket extender will never be overloaded as only two items are drawing current at a time and there is enough space between the equipment for dissipating heat.
It is however inconvenient to reach the ac extender to switch off the Quad although I know many prefer to leave amps powered-up permanently.
I am however a bit uneasy about this (leaving it on) and am thinking about fitting a suitable rocker/toggle switch to the Quad's back panel so I can turn off the mains.
I can work carefully and electrically safe. Does anyone have any opinions re this, please?
Other ideas are that I could possibly fit an ac inline switch to the powercord or does anyone know if a switched IEC terminated powercord is made?
Cheers
bulgin
Old 25th June 2006, 05:08 PM   #14
R.I.P.
there is a switched version of the IEC mains input socket. But I am fairly sure it will need a larger cutout than the standard socket.
regards Andrew T.
Old 25th June 2006, 06:51 PM   #15
Thanks Andrew
I'll check it out tomorrow at an electrical wholesaler but I'll think twice if the cutout will have be made bigger.
I have fitted these IEC sockets to many things like my pre's and quite a few tt's as they are so convenient and allow better quality powercords but I usually avoid hacking stuff unless the end result looks like 'the factory made it so'.
bulgin
Quad 405 Mk 1Hide this!Advertise here!
Zen Quad 22 johnm Tubes / Valves 0 13th June 2008 03:21 PM
pcb for quad 405 kanjumi Solid State 6 3rd April 2006 05:03 PM
A new Quad ESL?? Audiofool Planars & Exotics 12 17th November 2005 10:00 AM
quad 909 dj_maxxro Solid State 0 4th October 2005 04:11 AM
