A CFB BJT preamp - any comments?
Old 21st June 2006, 07:58 AM   #1
PMA is offline PMA  Europe
PMA's Avatar
Default A CFB BJT preamp - any comments?
Here it goes:
Old 21st June 2006, 08:04 AM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
First: 100 ohms input impedance? A bit low, don't you think?
Second: As amp it will work but you must consider different transistors (not 100% alike) and establish working conditions.
Your design is pretty much alike mine and it works splendidly. As pointed out earlier, the power supply must be clean due to poor PSRR.
You must have 22-47 pF at least from the Q11, Q12 collectors down to ground in order to get a nice step response.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 8 pcb's in interest so far.
Old 21st June 2006, 08:06 AM   #3
PMA's Avatar
Per,
an experienced designer like you knows that there is a high impedance input (+IN) at emmiters of Q1-Q2.
Old 21st June 2006, 08:10 AM   #4
peranders's Avatar
Since it's an inverting amp R2 is more or less the input impedance, yes Q1, Q2 is grounded, yes?
Old 21st June 2006, 08:17 AM   #5
PMA's Avatar
Any problem to ground R2 and have input at Q2-Q3 emitters, resulting in non-inverting amp??
The circuit is a hint, not a cookbook.
Old 21st June 2006, 08:23 AM   #6
PMA's Avatar
Default Non-inverting
is here:
Old 21st June 2006, 08:27 AM   #7
peranders's Avatar
That's better if you really ment "non-inverting" but what sort of comments did you want?
Old 21st June 2006, 08:34 AM   #8
PMA's Avatar
There is a difference in behaviour of non-inverting and inverting circuit of this kind. For gain like 10x it does not matter, for 1x the inverting behaves much better. We could increase input impedance of the inverting to some 1k and FB to 10k and still having excellent parameters. Buffer at the input would be needed. Not a case for non-inverting.
What kind of comments? This is a "PIM-free" topology
Old 21st June 2006, 09:07 AM   #9
peranders's Avatar
10k is probably too much if you want max speed out of the amp.
Old 21st June 2006, 03:39 PM   #10
PMA's Avatar
10k would result in >200kHz BW, not SR limited. You may stay non-inverting with 1k FB resistor and BW >>2MHz.
A CFB BJT preamp - any comments?Hide this!Advertise here!
Good supply for preamp, Comments? Algar_emi Solid State 229 26th July 2003 07:16 PM
Gainclone as a preamp & power amp - comments please. UncleJessie Chip Amps 1 13th July 2003 03:13 AM
Comments on a preamp design mpeg7 Tubes / Valves 9 17th September 2002 10:46 AM
Copyright ©1999-2017 diyAudio
