About this PS Design and Ground Scheme - diyAudio
Old 1st December 2002, 02:35 AM   #1
aborza is offline aborza  United States
Question About this PS Design and Ground Scheme
I drew up this PS design and wonder if it looks ok. Everything on the design is stolen from somone. Thanks, Nelson (TOAO), Syl and others not named.
I am concerned with a few things:
Are all of those film caps on the electrolytics a waste?
Is the RC filter for the front end properly drawn?
How do I calculate the R and the C for that filter?
Is there a better design for the bridge diode snubbers?
Is the grounding scheme the right way to go?
The Schematic follows.
Old 1st December 2002, 02:47 AM   #2
halojoy is offline halojoy  Sweden
On Hiatus
I think Bridge B2 and B4 should be mirrored left to right
also B4 lacks one DC output
For the R in RC, you need to know how much voltage drop
you can accept. This drop depends on the current consumption.
After that you select the caps to acheive
the filter roll off frequency.
This frequency should of cause be somewhere below 100 Hz
to block hum from trafo, more or less.
A bridge rectifier produces 2x50Hz signals.
This cut off (f) can be as low as 1 Hz, with big Caps
RC=1/(2pi x f)
C=1/(2pi x f x R)
f=1/(2pi x RC)
Old 1st December 2002, 02:57 AM   #3
Talking Ooops
Saw something myself!
The output from B3 Should read "+V Right Driver & Output"
And
F2 and F3 might be replaced with four fuses on the other side of the node to the right. That is, one fuse for + and - for each channel.
Thoughts?
Thanks,
ab
Old 2nd December 2002, 01:11 AM   #4
Thumbs up Thanks
Thanks for the input halojoy.
The changes have been made.
ab
Old 2nd December 2002, 01:29 AM   #5
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
In the USA, the frequency of concern will be 120Hz.
Car amp design, differential input, ground Davide82 Car Audio 11 12th November 2008 07:41 PM
Active ground cmoy: Help me learn PCB design TheSeekerr Chip Amps 2 23rd July 2008 09:20 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Ground scheme athos56 Tubes / Valves 27 12th April 2007 11:34 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright 1999-2017 diyAudio
