Do i need a diode?
Do i need a diode?
Old 20th June 2006, 12:28 AM   #11
clem_o is offline clem_o  Philippines
If I understand this correctly, the LM386 circuit is used to drive your car amplifier's INPUTS, and thus you are using your car amp to drive an external (PA) speaker?
Cheers
Clem
Old 20th June 2006, 01:44 AM   #12
anatech is online now anatech  Canada
anatech's Avatar
Do i need a diode?
Hi Clem,
That's what it sounds like.
-Chris
Old 20th June 2006, 03:48 AM   #13
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
I think a single side supply OPamp may be in order here since the output impeadence required is around a K Ohm or so. Electrolytics in signal path.................
All the trouble I've ever been in started out as fun......
Old 20th June 2006, 05:07 AM   #14
Ok, since it's driving such a high impedance, and for voice:
- reduce output capacitor to 1uF
- put a NC relay contact where the speaker normally is connected. Wire the relay such that it energizes along with the amplifier (so when the amp is turned on, relay contacts become "open")...
Not sure if the relay will be fast enough to catch all of the noise - perhaps people reading this will have a better idea - but the change from 470uF to 1uF output coupling should reduce the transients significantly!!
Cheers!!
Old 20th June 2006, 01:23 PM   #15
anatech's Avatar
Do i need a diode?
I think the problem is more fundamental. Your DC point at the output is biased around B+ / 2. That means you must charge the cap and discharge the thing every time you use this. I can see two solutions.
Either add a bleed resistor across the output and reduce the cap size, leave the unit powered on before and after you use it. Current drain is low, so let it run all the time the car is running or in ACC mode.
Or, generate a negative voltage and use a standard op amp circuit. Your output DC would then be close to 0 VDC. I'd still recommend letting the unit run before and after use to prevent switching transients.
-Chris
Old 20th June 2006, 01:56 PM   #16
jneutron is offline jneutron  United States
jneutron's Avatar
-Chris
I'd be more inclined to worry about the DC potential at the mike. When the switch is opened, the mike discharges the input capacitor....with gain..
Cheers, John
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
Old 20th June 2006, 02:03 PM   #17
anatech's Avatar
Do i need a diode?
Hi John,
Yup. Very good point.
Allowing the circuit to run will avoid the noise, but not the issues.
-Chris
Old 21st June 2006, 12:21 AM   #18
Agree with the comments - though it will take a bit of effort to really get the 1/2Vsupply to zero (additional circuits etc). Why not just shrink the capacitors - perhaps a little 'tick' on turn-on/off is tolerable to the user? In that case, maybe simply changing the output coupling capacitor to a 0.1uF will do...
Cheers!
Do i need a diode?Hide this!Advertise here!
SMD diode ID please Perry Babin Parts 6 4th February 2014 06:50 PM
Diode help dognut Parts 2 11th May 2009 10:41 AM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
What is this diode for? lumanauw Solid State 15 6th January 2007 05:14 PM
