I want to build a channel selector/mixer, followed by PGA2310. Most natural choice is virtual ground with some sort of switches. Now I have a couple of SSM2404 laying around. These switches are supposed to be absolutely transparent in current switching (as any other solid state switch, see SSM2404 datasheet for demonstration) and allow much more compact layout than say relays (example pcb attached).
A handful of relays is also an option but good ones are not cheap, take a lot of space, draw more current etc but supposedly give better performance. Now, given that SSM2404 has already vanishingly low THD levels, would it make any sense to use relays instead (audiophile superstition exluded) Datasheet: http://www.analog.com/en/prod/0,2877,SSM2404,00.html
Nothing is as simple as it seems |
#2 | |
On a related topic, have you tried discrete JFETs? I knocked together a sim using a PMBFJ176 and a PMBFJ112 back-to-back, and was very happy with the results. I found using N and P channel devices cancelled out much of the charge injection when switching, and reduced the distortion significantly. I simulated a differential seven stage attenuator using no less than 21of these, and managed 0.0002% THD at 1KHz. I can send the sim files if you like. It'd be a complex beast, but no doubt heaps of fun to build. Cheers, Suzy |
#3 |
WXN: I have used them in a few of my preamps,I have no complaints they perform quite well, others in this forum have used them also.
Bob C.
One man's magic is another man's engineering. |
#4 |
The SSM2404 (quad) and SSM2402 (dual) are great for "click-less" switching. I find them great to replace other logic devices like the 4513 often used on DAC's. They can provide a major improvement.
Since they are logic based, they are easy to integrate into existing logic circuits. However, if you are designing a circuit from scratch, then you have to consider that the SSM2404/2 needs a logic circuit in order to function. Some people like this, others do not. So, in my opinion they are slighty more complicated than a simple SPST relay. You use TTL/CMOS for control rather than current. Also, if you need a SPDT switch, you have to use a DPDT format which can eat up the SPST switches per IC very quickly. This if fine for designing new circuits but knid of a pain if you modifying an existing one. As anything there are pros and cons. BUT in the DIY world where you may be trying to make the best "whatever" you can,the SSM2404/2 is, in my opinion, often times better than a relay due to expense, size, and most of all sound. K |
#5 | ||||
no-spam at kipsus dot info Btw, any CMOS switch will be virtually distortion free if used in virtual ground mode because Ron is then very stable and so THD is very low. I'm concerned about crosstalk though. SSM2404 datasheet mentions VG switching and extremely low THD but not a word about crosstalk. No good if it's then -50db (because of the tradeoff between THD and isolation, depending on the load) Quote:
![]() Is there a schematic published anywhere? If not, could you share the SSM2404 section? Quote:
And btw, for those who don't know - SSM2402 is the same as SSM2404 but a dual instead of quad and has MUCH better specs. I even think it can be safely used in voltage switching too.
#6 |
You are right about relays. If they are from a quality source they "should" not degrade/alter the signal. When I said sound, I should have clarified it, I meant the sound of switching on and off. Relays are used often in recording equipment (my background). They can cause clicks and pops which are annoying. Whereas the SSM chips in question are "noise-less" in this regard.
K |
#7 |
The SSM2404 are just great
I use it in all my preamp projects....
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#8 | |
http://www.littlefishbicycles.com/misc/attenuator.asc http://www.littlefishbicycles.com/misc/jfet_switch.asc http://www.littlefishbicycles.com/misc/jfet_switch.asy Cheers, Suzy |
#9 | |
may I ask you for further elaboration (shematics, ...)? Best regards, |
#10 |
Interesting project. I'm still in need of an attenuator for my system (when it's completed), and it'll need to be a six channel one. 3 of these boards looks like a possible option. How many attenuation levels does this give? I guess a PIC is ideal to control these?
With regards to crosstalk, the top of the datasheet says "low crosstalk: -94db typ", but this may be measured differently to what your doing. As you can tell this isn't something I know much about but it caught my attention as its something I will be in need of! |
| ssm2404 schematic help | feathed | Solid State | 4 | 9th April 2009 04:29 AM |
| Good sound without bothering neighbours? | alexclaber | Multi-Way | 31 | 27th September 2008 11:59 AM |
| Is it worth trying to fix a car amp? | Datoyminaytah | Solid State | 2 | 5th August 2004 12:54 AM |
| Page generated in 0.13302 seconds (85.64% PHP - 14.36% MySQL) with 11 queries |
