nad 3020i harsh sound
Old 30th November 2002, 05:13 PM   #1
mad_z is offline mad_z
Question nad 3020i harsh sound
Hi Folks!
I've just connected old NAD amp - 3020i into my loudspeakers and to my surprise one of the speaker give quite harshy, disturbed and unclean sound. I 've checked if everything is well with connections, speaker and cd-player and it's ok. Propably there is a damage in left channel and being a begginer in diy I ask for help - what part/parts may be damaged? I want to exchange bad parts and listen to this oldie.
Which parts I shall check first? Any hints?
Thanks for any help. mad_z
Old 1st December 2002, 12:18 AM   #2
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Bad transistors, capacitors or diodes ? Who knows ? Did you change the speakers from left to right on the amp to exclude the possibity of a bad speakercable/speaker ? And did you swap the left and right input cable to exclude a maybe broken cdplayer/tuner/inputcable etc. ?
Just to make sure it really is the left channel of the amp that's causing the problem
I think it is wise to download the schematic and compare the measured voltages of the bad channel with the good channel. Maybe it's even wiser that a more experienced person helps you repairing this amp.
I found a schematic of this NAD here:
http://steve.sky.net.ua/a_index.htm
And here:
http://www.gmweb.btinternet.co.uk/others.htm
It's only audio. Member of the non modular PCB design committee
Old 1st December 2002, 07:44 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Good advice on making sure it is the amp 1st.
Both the sites mentioned have schemas from the original 3020 (and there are at least 2 differenet versions of that). I have the 3020i Map 710 kB. A teaser is attached.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st December 2002, 09:55 AM   #4
jean-paul's Avatar
Thanks Dave,
I wasn't aware of the small "i" behind the productname
Good reading is an art.
Jean-Paul
Old 1st December 2002, 10:14 AM   #5
Hamish is offline Hamish  Australia
Hamish's Avatar
mad_z,
i am undertaking a similar project (both amp and symptoms). i've found that the electrolytics and the transistors are the most likely suspects. i hope the guys here can help you as much as they have helped me
good luck, and don't give up.
Old 1st December 2002, 10:45 AM   #6
halojoy is offline halojoy  Sweden
On Hiatus
Default Old Electrolyt Caps
When we mention change of old electrolyts
we mostly think of the exchange of the BIG power caps.
They surely can have the toughest task
and maybe a higher temp during work.
So they dry out faster.
But all electrolyts gets bad with time.
More or less.
There are many Elyts in those old amps.
Even in signal's way.
Many of those can, nowadays be totally replaced by FILM caps.
Often with half the capacitance.
Because of the wide tolerance in elyts,
the designers probably selected more than needed,
to be sure to hit the value.
Old 1st December 2002, 01:31 PM   #7
jean-paul's Avatar
Default Probably ???
Halojoy, I would never advise to use half the value when replacing electrolytics for film caps
You can always calculate the -3 dB point to be sure if you persist on doing so.
Old 1st December 2002, 02:44 PM   #8
Thanks Jean-Paul, Hamish, Planet10 and Halojoy. I've checked speakers and connectors by swaping left and right channel of cd and then the speakers - and the problem is still in the same channel.
I have suspected electrolytics an transistors. I've read on some article that it's often to hear such disturbances when there is a damage in caps.
Using the scheme I will check voltages, and maybe at once exchange electrolitics . I've already found e-supply with original motorala bipolars, and good caps are available too.
Thank You for hints. Let the story begin
Old 1st December 2002, 03:17 PM   #9
On Hiatus
Default There is a reason .... ("Let your love flow")
There is a reason for my advice.
We live in a big world, you know.
Reality is not the same for all of us.
Low Wth (Wallet-thickness) is only one reason,
that my advice is not for optimal audiophile high end upgrade.
Still it is an upgrade.
I often adjust my advices to suit "a worst case situation".
This is not my situation.
But it can be a potential friend's situation.
Lyrics: "Let Your Love Flow"
Let your love fly, like a bird on a wing
And let your love bind you, to all living things
And let your love shine, and you'll know what I mean
That's the reason
"Bellamy Brothers"
a superhit some time ago
Old 1st December 2002, 04:35 PM   #10
Orgonom is offline Orgonom
Hallo mad_z,
i had the same problem with this amp.
Anybody tried to fix the problem in the finalstage
without success.
The real fault was a dirty switch!!!!!!
The output was distored in a way you see when one half of the finalstage is death.
After cleaning everything was ok.
Andreas
nad 3020i harsh soundHide this!Advertise here!
NAD 3020i repair help? wwenze Solid State 29 20th January 2012 08:48 AM
Flat FR, harsh sound??? Klimon Full Range 2 8th September 2006 03:10 PM
NAD 3020i Hum otherside Solid State 7 27th July 2006 08:08 PM
Remove LM3886 harsh sound soundNERD Chip Amps 32 3rd March 2006 04:41 AM
