Hello, do you think this amp is designed good enough?
I am planning to use it bridged, but I read here some threads where bridging a certain amp was said to be unstable or what. More, i want to increase the driver voltage by 10V, for the MJE350 and prats to the left. The power supply is gonna be +-48V, plus the 2x10V for the driver, I want to get 350W@8oms, into only a woffer, because it will be amp for bass guitar. |
#2 |
That's a modified Crescendo amp.
I would rather build one of Quasi's (a forum member) design, or an Anthony Holton design. |
#3 |
Are there other opinions?
#4 |
A) Those MOSFETs are expensive, and you will need three pair per half of the bridge amp to drive 350W/8R reliably.
B) Those MOSFETs sound a bit 'muddy' to me. I prefer a 'tighter' sound to my bass. C) For a similar front end with a more robust output stage that sounds 'tighter' and costs less, I would build the Super Leach. http://users.ece.gatech.edu/~mleach/superamp/ A similar version of this amp was produced commercially as the Heathkit AA1800. It tested at 400W/8R with ±95V rails. If you already have your suppy bought, just build a pair of the v4.5 Leach and bridge. It will put out the same power, and a pair uses the same number of output devices. |
#5 |
Did it Himself
No amp becomes unstable by bridging. As long as you observe the impedance considerations you will have no problems from an otherwise working amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
actually in the previous version of this I used IRFP150/9150, and it sounded good to me, but there was a weak transformer.
#7 |
Could anyone post here some good schema for a preferably mosfet-amp?
I have a pretty good source of mosfets in TO-247 package, so it´s cheaper for me to use them. |
#8 |
I like the Pass/Thagard A75 - see www.passdiy.com
I modified it slightly for 65V front end and 59 V output rails (42VAC transformer) You could go a little higher rails, but cooling the front end becomes an issue unless you redesign to reduce current in the VAS. I run 6 pairs of Fairchild IRFP240/9240. I've also bridged Leach 4.5s on 60V rails - performed quite nicely into 8 ohms. You could easily modify it to run on higher rails, just use MJE15032/33 drivers and MJL4281/4302 or MJL3281/1302 for outputs. Follow Leach's directions for the front end changes. It wouldn't be too difficult to modify the Leach for a MOSFET output stage - replace the Vbe multiplier device with a mosfet like IRF610 mounted on the heat sink, and skip the compensation diodes, and change the base stopper resistors from 3R3 to 221R or so. Power the front end from a separate regulated supply and away you go. I haven't actually done this yet, so beware. |
#9 |
go Quasi, He gives good support.
regards Andrew T. |
#10 |
I tried to search, but i didn´t find any of Quasi´s amps. Does he have any website?
| BiCMOS Bipolar+MOSFET better than MOSFET | lineup | Solid State | 5 | 8th December 2009 11:46 AM |
| bridged amp please help | Dan2 | Solid State | 5 | 27th April 2008 12:34 PM |
| Bridged (BTL) A75 Help please | damacles | Pass Labs | 7 | 26th April 2008 01:34 AM |
| Bridged amp pt.2 | Gabevee | Solid State | 1 | 24th July 2002 03:11 PM |
| bridged SOZ | FBLEAGH | Pass Labs | 5 | 24th September 2001 01:32 AM |
| Page generated in 0.09839 seconds (78.82% PHP - 21.18% MySQL) with 11 queries |
