Hi all,
I found something odd with my Quad 405. When idle with no input and no speakers connected it runs hot in a couple of minutes on my testbench. The output transistors are connected to a 4x50x130mm piece of Al. In Bernd Ludwig's mods F1 Appendix it's explained how the circuit works so I checked the voltages on my Quad and I don't understand why the colector of Tr7 is with more than 1.2V above the specified. In the attached image I wrote the voltages from my Quad on the original design with two mods specified with red dots (I know that it's ugly...). Also I implemented Bernd Ludwig's other modifications and the input mod from dc-daylight.co.uk Do you have any ideeas where should I start do debug? Thank you, Zsolt |
#2 |
They shouldnt run hot at all, i built a 405 a while ago and they o/p transistors were stone cold until a signal and load were connected. The only time they ran hot was when i accidently put them into class A operation (lol dont do this!). If the driver transistors run hot however this is fine as they are running class A by design, Tr7 should be noticably hot/ warm at idle. The collector of TR7 is more positive because you have added another diode to the bias set up, although i dont know why it has increased two diode drops? I am no where near as clued up on electronics as lots of others here, so i hopw what i said is helpful to you. I reckon that you circuit is likely to be fine, as long as the output transistors remain cool i think your just feeling the class A driver heat up. Regards Craig |
#3 |
Craig,
Yes, the voltage drop on the diodes it's strange for me too. I changed them to 1N4007 and now the woltage drop is around 0.7V on them. Reading Bernd's explanation about how the output stage is working I made some more measurements having the amplifier in idle (no input, no speakers). The "idle current" (the current that runs down through R30/31) is ~50mA (wich is good having 55V instead of 50V); the current through R38 when idle is ~34mA and the current at Tr8 collector is ~22mA (~0.5 enough to open Tr10). Maybe I missunderstood the explanation of how the dumpers are working but I found strange that the base voltage of Tr10 in idle mode is enough to open (~0.5V) it. So both Tr8 and Tr10 are working in idle. Also, the base-emiter voltage of Tr9 is 0.27 when idle, and even if I connect the speakers and put some music (having ~10W) it increases only to ~0.35V, which is not enough to open it. As I understand the whole positive output-swing has to be dumped by Tr7. Any ideeas are welcomed! Zsolt |
#4 |
In the previous message I missed the question
Is it normal with the Quad 405 to have the following values: In idle (no input, no speakers connected) to have: - a current of ~34mA running through R38 ? - a collector current of ~-22mA for Tr8 (~0.5V (with respect to V-) enough to open Tr10) ? - a base voltage of ~0.27V (with respect to the emiter) for Tr9 ? Having a source signal (music) of ~100mV at the input + speakers connected to the output to have: - a current of ~38mA running through R38 (I have added D13 as suggested) ? - a base voltage of ~0.35V (with respect to the emiter) for Tr9, so not enough to open it ? I'm just a hobby electronist so maybe I missundertstood something in the design or functioning of the Quad 405. Thank you, Zsolt |
#5 |
Zsolt
Did you move C8 ?? or simply short C11 (C9) Have you checked for high frequency oscillation ?? Regards Keith |
#6 |
Keith,
I moved C8 to the collector of Tr2 and I took out R23 and shorted C11. I also took out the components that are part of the limiter circuit. I tried to move C8 to the emiter of Tr2 but it oscillates on a hearable couple of KHz (at least I think so) and the offset voltage (the output voltage with no input and no speakers) raised from ~0.5mV to 40-50mV. I moved C8 back to the collector of Tr2 then. Unfortunately I don't have an oscilloscope to see the real output signal. I haven't checked for high frequency oscillation but I'm starting to think that could be the real problem. The PCB is handmade and has lot's of straps in the output part and three prity big home made inductors which are very close to each other. The output transistors are 2SC5200 which are fast and the OPA627 is sensitive too. I tried a couple of modifications on the PCB so it looks like a trench. I simulated the circuit with Workbench and with D13 inserted the voltage at the collector of Tr7 (when idle) is ~1.29V, what really should be. It remained at ~1.29V even if I increased the PSU voltage from +-50 to +-55V. I have a PSU with +-55 after rectification. The collector voltage raised only if I put a signal to the simulated input. The simulated Quad started clipping for an output of ~34V and input 1.27V. I think these values are ok. I think I will drop this homebrew design and buy a ready made hungarian Quad 405 clone, like the one on the link, and do the modifications in half a day. The clone cost is ~25euros Regards, Zsolt |
#7 |
try to use a slower opamp
#8 |
I could try to put back my TL071 but I don't want to skip the OPA627 anyway.
Could be that the big inductors, the maltreated PCB and the 30MHz 2SC5200 is the problem? |
#9 |
I meant it could be the OPA627 oscillating, the spec sheet says that you must put 0,1uF caps on the +/- to ground. The "power supply" to the opamp is very crude - only a zener. You can also try putting a 22uF tant over the zeners + the 0,1uF caps...use the TL071 to test if the osc. stops...
#10 |
I soldered two ceramics 100nF capacitors straight to the opamp supply pins. Also the amplifier board is decoulped by 100nF + 100uF on each side.
| quad 606 mk1 problem | kokheng | Solid State | 2 | 4th February 2009 01:26 AM |
| Quad 405 hum problem | vzs | Solid State | 16 | 7th June 2006 09:26 AM |
| Quad 405 problem | emperor | Solid State | 5 | 14th July 2005 10:09 AM |
| Taking a chance here - problem with DC voltages | arnoldc | Solid State | 5 | 21st September 2004 11:23 PM |
| Source output voltages and more | Sandy H. | Chip Amps | 0 | 30th August 2003 04:21 PM |
| Page generated in 0.14564 seconds (74.00% PHP - 26.00% MySQL) with 11 queries |
