FET inputs or bipolar inputs on a power amp? - Page 2 - diyAudio
Old 17th June 2006, 10:43 AM   #11
ash_dac is offline ash_dac  United Kingdom
Originally posted by AndrewT
there's something else I didn't know.
Low pass filter with rising distortion in the pass band due to high source impedance is instructive!
http://www.elecdesign.com/Articles/I...ArticleID=7206
I found this to be a good explanation.
I can see why few people / companies use them on the input stage. Matching the input fet's must be a real pain considering that they are relatively expensive , and used in cascaded inputs.
Old 17th June 2006, 01:52 PM   #12
pooge is offline pooge  United States
Here's another opinion
"FETs seem a poor idea for the input stage. The basic gm is so low compared with BJTs that there is little scope for linearisation by adding source resistors for local degeneration, so an FET input stage will be very non-linear compared with a BJTs degenerated down to the same transconductance: see 5.1.3."
http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm#7
Old 17th June 2006, 06:54 PM   #13
john curl's Avatar
Actually, there is some rationale for this opinion, but it fails in practice when you consider the ORDER of the distortion components, input noise contribution, and bias current compromises. A fet stage can be quieter, have virtually no bias current, and have essentially the same magnitude of linearity as a bipolar input stage.
If you are willing to risk FM distortion, a bipolar pair can be acceptable, so long that it doesn't have any significant resistor degeneration . Test equipment input stages are one place where this might be acceptable, if the test equipment is designed for measuring AM distortion only. For hi Z inputs, however, fets are always better by far, for more reasons than I can describe here.
Old 17th June 2006, 08:58 PM   #14
traderbam's Avatar
Would you please explain this statement?
Old 17th June 2006, 09:20 PM   #15
kevinkr's Avatar
Linear Systems makes matched fet pairs that would be very good in the front end of an audio amplifier as part of a long tail cascode pair.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 17th June 2006, 10:59 PM   #16
darkfenriz's Avatar
Yeah. Gramatically at least. English is not my mother tongue, same as many others'.
Old 18th June 2006, 12:32 AM   #17
john curl's Avatar
FM distortion is generated by the non-linear S curve that exists WHEN you want BOTH low noise and a bipolar transistor input. Degeneration resistor free bipolar input stages have a significant amount of FM distortion, unless the open loop bandwidth is very, very high, or the gain bandwidth is very, very high. You know: Very, very high implies qualities that higher than usually affordable by most people.
A good example of this is the AD797 op amp, or even the 5534 op amp and its relatives.
Old 18th June 2006, 01:35 AM   #18
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Well,using JFETs or BJTs as input stages also depend on your circuit configuration,whether a conventional differential stage or a fully complementary push pull.
Old 18th June 2006, 01:45 AM   #19
john curl's Avatar
Why?
Old 18th June 2006, 02:09 AM   #20
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Mr Curl, how bad it is the differential input pair of bipolars without RE degeneration?
Copyright 1999-2017 diyAudio
