Old 27th June 2006, 01:52 PM   #101
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
however, on that same web site is Leach's RIAA preamp which uses 2N5457 JFETs at the front end.
mlloyd1
Originally posted by ash_dac
From the Leach amp pages...
"Because FET parameters are so unpredictable and FETs are more susceptible to flicker noise, I prefer the BJTs with emitter resistors." http://users.ece.gatech.edu/~mleach/lowtim/bckgrnd.html
Is the unpredictability a problem inherent in the manufacturing of FET's ?
http://users.ece.gatech.edu/~mleach/ece4391/noise_b.pdf
Old 27th June 2006, 03:22 PM   #102
gerhard is offline gerhard  Germany
gerhard's Avatar
It is _much_ easier to control the dimensions of vertical structures
by choosing diffusion time rather than controlling horizontal structures
with masks, exposure and etching. This was THE breaktrough of the
planar process.
FET channel length and width usually depend on horizontal structures.
This unlucky fate is shared by lateral PNPs that exist in some low cost
bipolar processes, where the extra diffusion steps needed to produce
nice PNPs are to be avoided.
Gerhard
Old 27th June 2006, 03:46 PM   #103
pooge is offline pooge  United States
mlloyd1
He used them in this application to mate better with a phono cartridge. Less base current, lower noise with cartridge source, etc.
Old 27th June 2006, 09:19 PM   #104
I am very surprised that anyone in the last 30 years, would use a 2N5457 fet for a phono input. It IS too noisy, but many fets, both American or Japanese, are better than almost any bipolar transistor, 1/f noise included.
Old 28th June 2006, 01:08 AM   #105
Fanuc is offline Fanuc  United Kingdom
Default What about the power amplifier compensation?
Ho Hum...
I have never personally seen any spectrum anaylisis of outputs to the VAS of jfets/mosfet (matched/unmatched - with all it's incipient problems) cascodes versus single bjts with and without current mirrors. Just another ten dimensions are added etc....
I think the multiple Vgs spreads compared with the single Vbe of BJTs means in a differential it is a sub optimal subtractor - much more incorrect from the audio signal. Monolithic op amps are a very different technology.a
There not the same.
What the hell has input noise to do with a power amplifer anyway?
Old 28th June 2006, 04:46 AM   #106
It WAS designed 30 years ago, when those noisy LPs were sold.
Old 28th June 2006, 07:00 AM   #107
PMA is offline PMA  Europe
PMA's Avatar
Yes - low noise RIAA preamp has always been greater challenge than a simple link level stage with linear gain 2x or so.
Old 28th June 2006, 07:24 AM   #108
An even greater problem is with the reproduce noise of analog tape recorders. This is even more difficult than RIAA reproduction, because of the absolute output vs inductance and the lack of high frequency falloff after a 50us time constant or so. In those early days, we sometimes used selected fets, but it was marginal. By 1973, however, we found solutions to this problem and dropped the input noise with fets to less than 2nV/rt Hz. Today, we can do about 1nV/rt Hz differential, and 0.4nV/rt Hz for special function inputs like moving coil.
Old 28th June 2006, 04:51 PM   #109
ash_dac is offline ash_dac  United Kingdom
Default Back to the Butler input / OP275
Butler design:-
http://www.freepatentsonline.com/5101126.pdf
The text is in patent speak but suggests that the BJT works for low input signals, and the FET works for higher input signals.
Is there any value in this approach ?
see also:-
Butler input pair
Old 28th June 2006, 05:01 PM   #110
This design is problematic, for reasons other than noise.
Copyright ©1999-2013 diyAudio
