Old 11th June 2006, 08:11 PM   #1
Default Krell - "differential circuitry" and a **** up
OK, this is where I hold my hands up and say what an idiot I was, but it's done now and I need some advice (after the horse has bolted natch). If I'd read the handbook of the Krell KAV 300iL properly I would have seen this statement (in small print): ""The differential circuitry employed with the KAV 300iL requires special attention when connecting speakers... Do not attempt to bridge the left and right speaker binding posts..."
You see where this is heading? Needing mono operation to A/B some speakers with and without cabinet mods, and the Krell like most amps not having that most useful of features a mono switch, I commoned the positive speaker connections. Job done I removed the common link and found that I'd blown one channel (there is some output but it is way down). It's not the speaker fuse. I'm bracing myself for an expensive repair job, but before I send it off I thought I'd ask here to find out if there's anything simple it might be. Any ideas?
Tim
Old 14th February 2007, 04:01 PM   #2
K-amps is offline K-amps  United States
K-amps's Avatar
DC rail fuses?
One rail running will give some output but disort when pushed...
Got pictures of the innards?
JVC "EXU-901a" (KRELL KPS-25sc Phase Tech CT-1 CT1) better than VAM1254, CDpro2LF ? tiefbassuebertr Digital Source 14 12th January 2012 08:12 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Need help to build "Krell KSA-50" space2000 Solid State 12 7th August 2008 01:53 PM
Krell's "Sustained Plateau" Design - some thoughts bear Solid State 19 1st November 2004 07:24 PM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.05176 seconds (80.81% PHP - 19.19% MySQL) with 10 queries
