Hello.
I just finished this preamp. http://www.albertkreuzer.com/preamp.htm And now for the big question.. It wont play. The problem is not in the psu. That delivers +/- 15V as expected. Should I take off all potmeters and switches and put them on one by one or how would you errortest it? When I've had power on it and I turn it off, the threshold LED turns on for ˝ sec as the caps are discharging I suppose. When I put in a pair of headphones and turn up the gain I hear a click-like sound when the meter is about 2/3 turned up.. P1 and P7 are both in middle position. As well are all meters. Any ideas or could the problem be anywhere? Thanks |
#2 |
First check the voltage on all + parts of the transistors, and the both supplies of the op-amp.
If it doesn´t help, then I would suggest making a signal-probe. As it is a bass preamp, you could take a tape player and connect it to the input. Then connect a jack-jack wire to some combo, make the shield grounded to your circuit, and start touching the signal part of the ciruit with the tip of the jack, and listen where the signal ends. |
#3 | |
Do you mean measureing the gate on the fets? And in that case how should i measure? What should i look for. I just tested the opamps.. they get +/- 15V on the correct legs. Im a beginner so bare with me Thank you |
#4 |
by the +parts I meanrt the legs of the transistors which are connected to the +voltage, check the voltage by multimeter.
#5 | |
8,4V on T1 5,89v on T2 15,25V on T3 but i dont know if this is what its suppose to be.. Any ideas Thanks |
#6 |
seems OK. Now you should do the signal check, and you can also check the G-S voltages.
#7 |
Ok first the G and S voltages..
T1: 8.4 D 1.21 S 0.02 G T2: 5.89 D 5.10 S 5.10 G T3: 15.25 D 4.52 S 1.99 G Ill see if I can figure out how to do that signal check now. |
#8 |
about this signalcheck.. Could I plug in a mp3 player, and then use a pair of headphones, grounding the common and one of the speakers and using the tip on the headphonejack to probe on my pcb? That way just listen how "far" the signal gets in the path.
Or how would you do it? Thanks |
#9 | |
Any ideas? |
#10 |
Hi XXLPeanut,
Are you sure your jacks are wired with the resistor between them and the summing point? Are the resistors the correct value? -Chris |
| finished my PCC88 preamp | Roemhild | Tubes / Valves | 12 | 18th January 2012 08:04 AM |
| PGA2310 based preamp finished | bostjancek | Chip Amps | 24 | 19th July 2010 08:59 PM |
| Will a tube preamp play nice with a F1? | G | Pass Labs | 9 | 15th March 2009 11:46 PM |
| Giaime's Preamp Finished!!! | Giaime | Tubes / Valves | 19 | 17th May 2006 07:36 PM |
| Just finished my first tubes-preamp | Ralph | Tubes / Valves | 7 | 26th April 2002 09:26 AM |
| Page generated in 0.10183 seconds (82.62% PHP - 17.38% MySQL) with 11 queries |
