Old 11th June 2006, 06:00 PM   #1
KU40 is offline KU40  United States
Default 7812 vs 7912
I am repairing an amplifier and I think a 7912 regulator is bad. What's the difference between the 78 and 79? Radio shack apparently only carries the 7812 so if I have to use a 7912 I suppose I'll have to order it from somewhere else.
Old 11th June 2006, 06:02 PM   #2
7812 = positive bus voltage regulator.
7912 = negative bus voltage regulator.
The point of life is to build atleast one audio amplifier before you die.
Old 11th June 2006, 10:44 PM   #3
latala is offline latala  United Kingdom
please alsop note that the pin connections are also different
regards trev
Old 12th June 2006, 08:51 PM   #4
down load the datasheets for each.
Lots of useful guidance and circuits as well as the techy jargon.
regards Andrew T.
Old 13th June 2006, 03:30 PM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
From:Fairchild,NS,TI,ST.......................any of them.
7912 needing minimal load? Pierre Power Supplies 3 25th May 2006 12:28 PM
How do I know a 7812 is broken? ericpeters Parts 14 12th January 2005 11:15 AM
Lm7812/7912 kinser Chip Amps 9 22nd November 2004 09:55 AM
7812/7912 regulator questions Solid Snake Solid State 48 1st December 2003 05:42 PM
can I parallel 7812 Chips PaulHilgeman Parts 16 6th May 2003 09:05 PM
Page generated in 0.07457 seconds (70.01% PHP - 29.99% MySQL) with 10 queries
