Old 9th June 2006, 10:44 PM   #1
Send a message via AIM to EvilYoda
Default What Adcom amp are these modules out of and how can I use them?
Hi all, n00b here. A friend of mine was cleaning out his storage unit and sold these two modules to me for a fairly nominal price...I'm not concerned with how much I paid for them. I was wondering if anybody recognized what amplifier they were originally out of (he said that it was a 5 channel 200W Adcom...nothing comes to mind. edit: under the heatsink, you can see a part number with 1998 as the manufacturing year).
As you can tell from the pictures, they're pretty complete and they've been tested...he said that I all I need to do is supply AC and I'm good to go. The RCA input's on there and I've also included a picture of the "output" part...how do I use these? There's also a four-pin connection on the board with 12V DC/Clip/GND/Protec listed, is it necessary for me to use this information and regardless, how do I go about representing it? Are they all just LED indicators? Lastly, is a proper chassis necessary for grounding/? concerns?
Any help would be great as I figured this would be a nice way to get started on things...I can understand technical concepts fairly well, but I'll probably still be asking a bajillion questions.
Old 9th June 2006, 10:45 PM   #2
Default Pic 2
Just one module:
Old 9th June 2006, 10:47 PM   #3
Default Pic 3
Output closeup
Old 9th June 2006, 10:48 PM   #4
Default Pic 4
Power cable header (4-pin)
Old 9th June 2006, 11:00 PM   #5
Digging around a little bit, I found this image, which looks identical to my modules:
GFA-7700
I realize that this isn't exactly a great amp, but it'll work as an intermediate step to where I want to be.
Old 10th June 2006, 12:21 AM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi EvilYoda,
Actually, they are. What do you think the "G" in GFA stands for?
I'm not kidding.
These are better than your average multichannel amp. Enjoy them.
-Chris
Old 10th June 2006, 01:19 AM   #7
Yeah, I know they're pretty respectable...otherwise, I would've just gone with a cheap GC kit or something.
But now to figure out how it works
Old 12th June 2006, 02:24 AM   #8
No love for the newb...I don't imagine it's very difficult for someone that knows what he's doing.
bump.
Old 12th June 2006, 11:29 AM   #9
EchoWars's Avatar
I have a GFA-7000, and it uses the same type of construction, and the boards look just like that. But...the manual says the filter caps are 12,000µf 63V, whereas yours are 12,000µf 80V. Since the rail voltages on the amp are 63V, Adcom might have upped ther voltage...or you just have a different amp.
The GFA-7000, 7500, and 7700 all used this type of build.
You need a transformer (the diode bridge is on the module), and connections for input. There is also connections for a clipping LED, and thermal protect.
Old 13th June 2006, 04:04 AM   #10
Can you tell what ratings the transformers are since they're all monoblock designs? I'm working on all the connectors, but that's no big deal. Lastly, a few fuses...he had said something like an 8A fuse, but I dled the 7700 manual and it lists them as "for 115 volt operation...15 amp 250 Volt".
WTB: UCD400 or 180 modules. OR, some SKA Modules Spiritzly Swap Meet 0 27th September 2008 07:08 AM
Adcom GCD 575 milanomike Digital Source 0 23rd December 2007 06:39 AM
Adcom 2A IC for GFA 565 CompNut Solid State 18 2nd February 2007 06:16 PM
UcD modules - can the modules work without the input op-amp? beppe61 Class D 8 11th October 2006 07:35 AM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 08:09 PM
Page generated in 0.11288 seconds (75.07% PHP - 24.93% MySQL) with 11 queries
