Help me understanding this opamp circuitry
Old 9th June 2006, 08:53 PM   #1
Groundloops is offline Groundloops
Im amazed!
Groundloops's Avatar
Question Help me understanding this opamp circuitry
These are the partial pre and output sections of a Technics SU-C1010 preamp. I wonder for what the big elytic caps in the signal path are. (signal path is marked with arrows)
Im thinking of replacing the NJM4580s with OPA2134; would it be wise to take the said caps out ? Or what else is advisable to change ?
Thanks !
Old 9th June 2006, 09:04 PM   #2
traderbam is offline traderbam  Europe
traderbam's Avatar
Default hint
The NJM4580 has pnp bipolar inputs.
Old 9th June 2006, 09:24 PM   #3
Im amazed!
Im as wise as before ...
Old 9th June 2006, 09:31 PM   #4
sawreyrw is offline sawreyrw  United States
I don't know why you would want to replace the op amps with a different type. The big caps are AC coupling caps. I can't tell from the schematic you posted whether you need them, but I would leave them in.
Old 9th June 2006, 09:39 PM   #5
BobEllis is offline BobEllis  United States
BobEllis's Avatar
You definitely need them in the second part where the opamp runs single rail. That would not be the best place to drop in an OPA2134. You also need the left two in the first part, since that blocks the DC from the second. The output caps depend on what you are driving - if it is another single rail stage they MUST stay.
In the first part you could use an OPA2134, but again why? What are you trying to accomplish and what is the rest of your system? Whether it would make a difference depends on the board layout and other factors.
You'd probably get more bang for your buck bypassing the electrolytics with an MKP of 0.47 to 1 uf or so. Just solder them to the electro's pins on the bottom of the board.
Old 9th June 2006, 09:42 PM   #6
Im amazed!
Ive changed a 4580 in a cdp for a 2134 before by advice, and it really sounds better. So Id like to try this in my pre.
My knowledge in electroncs is very limited; doing not much more than soldering by numbers but all that went fine ...
Old 9th June 2006, 09:50 PM   #7
Im amazed!
Roger that !
So maybe here Ill just give it a try and if it doesnt work Ill change it back.
Thats what I will do in the second part and with the left two in the first part.
Thank you very much !
Help me understanding this opamp circuitryHide this!Advertise here!
LM3886 circuitry jmillerdoc Chip Amps 3 5th June 2009 12:25 PM
DC-Protect Circuitry Fritzell Solid State 96 1st December 2006 04:29 PM
About circuitry design, etc... J_Starner Parts 16 5th June 2006 01:30 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Using DC instead of Ac for some control circuitry filholder Chip Amps 3 2nd July 2005 03:53 PM
Copyright ©1999-2017 diyAudio
