Old 8th June 2006, 09:49 PM   #1
ash_dac is offline ash_dac  United Kingdom
Default Introduction to Power Amplifiers (Diy kit)
http://www.electronic-kits-and-proje.../3000/3048.pdf
Is the green LED used in the bias for temperature compensation ?
The power output is a bit low but I may try the kit as it could be modified for higher power (I only need 10W).
Any thoughts ?
Old 8th June 2006, 09:55 PM   #2
Tim__x is offline Tim__x  Canada
This doesn't look like a great amp to me. No collector load for Q1, poor temp comp. (Vbe multiplier would be better), no turnoff resistors for the drivers, poor low-frequency response (100ufs is to small). If you want more power, I'd pick a different design.
Clever bootstrapping, but that's about all I can say.
Old 9th June 2006, 08:39 AM   #3
Yes the green led is used for biasing, but temperature compensation is minimal.
I agree with TX's comments, you may learn something by building it
but an IC based solution for example will have far better performance.
The design IMO is not suitable to be scaled up to 10W.
http://sound.westhost.com/project72.htm
/sreten.
Old 9th June 2006, 04:53 PM   #4
thanks for the advice
Old 9th June 2006, 08:08 PM   #5
There are a lot of other good kits out there, and a few good boards (like the ones at Rod Elliott's Elliott Sound Productions).
Almost any amp can be scaled down more easily than up. ESP's Project 3A can be scaled down with only a change to supply voltage (15v+15v would be good), R8 (10k), R9/10 (1.5k) and C5 (220uf). Even that much is probably unneccasary.
Old 9th June 2006, 08:43 PM   #6
teemuk is offline teemuk  Finland
Every circuit can be scaled up or down and optimized but you have to know how to do it first. I have to admit that I liked the tutorial and I wish I would have seen it two or three years ago when I was still struggling to learn how simple power amplifiers work. It gives some food for thought and a nice alternative for building just chip amp kits. IMO it may be a very effective way to start learning about discrete amplifier circuits. Maybe the circuit does not impress with superb sound quality but I think the original idea was to keep it as simple as possible, otherwise it might scare away the people who know fairly little about PA circuits. I think, the design is fairly good for something with 1/2 to 2 watt power rating and serves the purpose of the kit well.
Old 10th June 2006, 01:36 AM   #7
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Hi ash(aka Peter Crouch???),Gainclone should be a good heardstart.
Old 10th June 2006, 12:22 PM   #8
I have purchased Audio IC Op-Amp Applications by Walt Jung for a good price.
I'm hoping this book will provide a good background reading for gainclones, preamps, IV convertors for current DAC's.
For Power amplifier design I was thinking about one of Doug Self's book.
Any thoughts ?
Old 10th June 2006, 12:27 PM   #9
pinkmouse's Avatar
Self is excellent, but technical. Slone might be an easier start.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 10th June 2006, 03:10 PM   #10
mikeks is offline mikeks  United Kingdom
Account Disabled
On the contrary, Self's book is concise and to the point...
Harrison Power Amplifiers Aug Solid State 9 24th March 2010 06:14 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
battery power suplpy for power amplifiers possible? tschrama Solid State 2 23rd April 2002 08:16 PM
audioxpress power amplifiers ogp Solid State 8 17th November 2001 12:46 AM
Page generated in 0.11536 seconds (80.33% PHP - 19.67% MySQL) with 10 queries
