calculating amount of current
Old 29th November 2002, 01:19 AM   #11
hacknet is offline hacknet  Singapore
would this mean that i need +28 and -28 rails with relation to gnd?
Old 29th November 2002, 01:41 AM   #12
eLarson is offline eLarson  United States
eLarson's Avatar
Maybe a couple volts more per rail to
ensure you get all the voltage swing you
need without clipping.
If you're using MOSFETs allow 4 volts more
on each rail. If its reg'lar transistors a couple
of volts will be good enough.
Erik
Old 29th November 2002, 02:17 AM   #13
Erik
mosfet has a 4 volt p2p lost izzit?
sillicon has 0.6v
germainium has 0.2
arnt mosfets sillicon transistors?
Old 29th November 2002, 03:06 AM   #14
halojoy is offline halojoy  Sweden
On Hiatus
Default MOS - Metall Oxide Semiconductors
Originally posted by hacknet
Aren't mosfets sillicon transistors?
It uses not Silicon, but an metaloxide.
What Oxide I do not know. Please tell us more!
Old 29th November 2002, 02:06 PM   #15
eLarson's Avatar
MOSFET stands for Metal Oxide/Semiconductor
Field-Effect Transistor. (This is to distinguish it
from the JFET or Junction Field-Effect Transistor.)
Anyways, the role of the Metal Oxide is to
insulate the gate pin from the rest of the body
of the device, which is generally silicon,
but it can also be Gallium Arsenide (GaAs -
these are often referred to as GaAsFETs).
The insulating oxide layer is the reason for
the really high resistance between the gate
pin and the source pin. It is also the reason
there is a highish capacitance between the
gate pin and the source pin.
A field-effect transistor works by setting up
a conducting channel from the source to
the drain when a voltage is applied to the
gate. The voltage at the gate (which is
insulated by the oxide layer from the body
of the device) sets up an electric field within
the body of the device. When enough voltage
is applied the channel is complete and
current can flow.
The value needed to activate this channel
is called the threshold voltage and it varies
from configuration to configuration. About
4 volts is a reasonable value to assume.
A really nice primer on using MOSFETs is
given in Nelson Pass's article on building
the A75 amplifier. You can download the
PDFs of part I and part II of the article here:
http://www.passdiy.com/legacy.htm.
Erik
Old 29th November 2002, 02:32 PM   #16
On Hiatus
Another way to calc the highest needed voltage.
VOLTrms=SQR(WATT x OHM)
This value is the RMS voltage. A sort of average for the whole sinus wave.
To get the peak voltage, where Sinus wave is at its maximum.
You just multiply with 1.4
So VOLTpeak= 1.4 x (SQR{WATT x OHM})
or VOLTpeak= 1.4 x VOLTrms
Old 29th November 2002, 02:38 PM   #17
UrSv is offline UrSv  Sweden
UrSv's Avatar
AND add the voltage drops. Say 4-5 V for FET and 2-3 V for bipolar.
/UrSv
Old 2nd December 2002, 06:13 AM   #18
thx... wad about calculating the current needed?
calculating amount of currentHide this!Advertise here!
Calculating current capacity? sorenj07 Tubes / Valves 12 23rd June 2009 10:28 PM
calculating transformer current draw question gary h Tubes / Valves 5 20th June 2008 01:14 PM
Calculating PS current for octal Aikido jrebman Tubes / Valves 4 25th March 2008 08:47 PM
calculating total current draw woodturner-fran Tubes / Valves 3 9th March 2008 11:11 AM
Calculating VAS current for mosfet output bogdan_borko Solid State 21 11th April 2006 03:57 AM
