Old 6th June 2006, 07:55 PM   #1
Default Help Problem With IRF610
I build maching mosfet from this .
http://www.diamondstar.de/transistor...ng_mosfet.html
Using 2.2K Ohm 1/4W and 15v PSU Using LM317
First Time I check 10 pcs IRF610 , Measure Vgs I get around ~3.5v up to ~4.0v
Test it several times Now I got Vgs Around ~0.5v
I try put in board all working but, I got dc offset ~3v up to ~9v
Put another IRF610 vgs ~3.5 up to ~3.7 I got dc offset -10mV and 70mv (only check one times)
Is IRF610 with Vgs ~0.5v has broken ?
Old 6th June 2006, 08:13 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Default Re: Help Problem With IRF610
Yes...
Mosfets are very sensitive to touching, the slightet ESD (Electro Static Discharge) kills them.
Typical Vgs of IRFs is ~3.6v.
Mike
Old 6th June 2006, 08:25 PM   #3
thanks mikeB
how to check without kill them ?
Old 6th June 2006, 08:29 PM   #4
MikeB's Avatar
Discharge yourself before touching the mosfets by touching something grounded...
Mike
Old 6th June 2006, 08:34 PM   #5
thanks mikeB.
I wait new amps from you...
Old 6th June 2006, 10:15 PM   #6
Very important for ALL the mosfets:don't forget to put a protection with 12V Zener and a normal 1N4004 or similar diode.According to my experience this is the main cause of mosfets dead (with the ESD voltage).
Old 7th June 2006, 10:00 AM   #7
Hi Parsecaudio,
your warning is very valid for low capacitance FETs, do you think that it applies to high capacitance power FETs?
I have handled and/or replaced many power FETs without problems nor earthing/static discharge leads/wrist bands: 2sk225/j81, 2sk1058/j162 and 2sk1529j200.
Before I touch my 2sk389/j109 I will need to invest in some earthing procedures. Just how far do I need to go? I use a formica table top for my assembly. Should this be replaced or covered with a conductive film?
regards Andrew T.
Old 7th June 2006, 12:18 PM   #8
PMA is offline PMA  Europe
PMA's Avatar
Mike
..... and hope the MOSFET has not lied on well insulated charged plastic wafer before you, properly discharged, try to touch it ...
Old 7th June 2006, 05:14 PM   #9
traderbam's Avatar
An easy, cheap precaution is to slip a paperclip across all three legs, assuming a flat package, and leave it there until you are ready to solder the device into the circuit board. I store my power transistors in anti-static plastic bags with paperclips on their legs.
A .model for IRF610? Onvinyl Parts 0 17th October 2007 11:57 AM
IRF610 replacement sherwood Pass Labs 24 24th July 2005 02:08 PM
Matching IRF610's TomT Pass Labs 18 23rd January 2004 08:29 PM
Looking for IRF610 and IRF9620 omar Swap Meet 0 23rd October 2003 05:49 AM
Boz Irf610 Pin? tone Pass Labs 5 29th November 2002 04:00 AM
Page generated in 0.10701 seconds (71.08% PHP - 28.92% MySQL) with 10 queries
