Can this be for real?! - Page 2 - diyAudio
Old 6th June 2006, 05:18 PM   #11
Banned
EEEEEEEK What in the name of **** **** was that thing driving ???
Old 6th June 2006, 05:28 PM   #12
Mr. Triatic's Avatar
it ain't a speaker, that´s for sure.. it's a kind of industrial application with a low and reactive load that need precise control.
www.joddla.net/audio/
Old 6th June 2006, 05:41 PM   #13
Banned
One of those inverter stations for powerlines over to other countries ? Induction heating machine ?
Old 6th June 2006, 06:18 PM   #14
The one and only
Nelson Pass's Avatar
Nobody seems to have noticed that the negative half of the
output stage has what should be the Source resistors on
the Drains. Clearly this amplifier was never built.
Old 6th June 2006, 07:02 PM   #15
bogdan_borko's Avatar
and this number of output devices could never be driven by this vas stage...
there is so much junk on the internet and we can`t help it
Old 7th June 2006, 01:11 AM   #16
kartino is offline kartino  Indonesia
kartino's Avatar
For so high voltage level must consider the power dissipation = loss power = heat. Then the choice is only lower rails = lower impedance or class G,H and class D,T. Hence simple rails to rails is not a choice.
However for that high power (32kW) must be in speaker array and better feed by multiple amplifier. I wonder that people think to make single amp at very high power = expensive = complicated (class G,H except class D).
Old 7th June 2006, 06:14 AM   #17
jan.didden's Avatar
Its not a 32kW amp, its a 7.2kW amp. And the heat would be no problem with that scaledup output stage.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 7th June 2006, 06:37 AM   #18
darkfenriz's Avatar
Exactly!
Moreover input polarities are swapped forming a positive DC feedback.
Old 8th June 2006, 07:43 AM   #19
kartino's Avatar
at that 8 ohm load speaker array of course.
Getting into LP... for real! DragonMaster Analogue Source 56 26th September 2006 10:18 PM
A Real Sub mikee12345 Multi-Way 10 10th March 2003 02:03 PM
Combing effects: How real in "real" rooms? smeade1079 Multi-Way 3 10th March 2003 12:32 AM
Copyright ©1999-2017 diyAudio
