Old 3rd June 2006, 10:18 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Question base voltage
For a BJT common base amplifier(which are found a lot in cascoded stages),how to determine the base voltage???
Old 3rd June 2006, 11:00 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
You look at the emitter voltage you want, and then the base voltage needs to be 0.65V or so higher (for NPN, lower for PNP).
Jan Didden
/Another new issue: Linear Audio Volume 3!
What about FETs for Cellular Base Stations in Audio Cascode Voltage Gain Stage (line tiefbassuebertr Solid State 8 23rd August 2009 02:53 AM
base-emitter voltage clovi_kate Solid State 7 22nd March 2007 08:20 AM
Transistor base negative voltage Bazukaz Solid State 19 31st May 2006 11:32 PM
base for amp karma Tubes / Valves 7 18th June 2004 03:03 AM
Bed base as a big sub? DPW666 Multi-Way 9 10th March 2003 07:48 PM
Page generated in 0.06684 seconds (72.19% PHP - 27.81% MySQL) with 10 queries
