diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Sony Schematics (http://www.diyaudio.com/forums/solid-state/80591-sony-schematics.html)
enzedone 31st May 2006 12:40 AM
Sony Schematics
I am looking for Schematics for a Sony Amplifier TA-313 from 1978-1979. If anyone could help?
Cheers.
Brett.
EchoWars 31st May 2006 09:49 AM
Check with this guy:
http://www.divdev.fsnet.co.uk/man.htm
jan.didden 31st May 2006 10:53 AM
www.schaltungsdienst.de , around 10 $,
SONY SERVICE MANUAL TA313 1166663 995845011 B
Jan Didden
enzedone 31st May 2006 10:25 PM
Cheers..............................:D
pejinm 11th January 2007 08:33 PM
Hi guys,
I have a problem with same sony amp. The chip (sanken - SI1125) is gone. I want to replace it with similar STK. Found STK4133, 4132II in store, but I don't know pin layout of the SI1125 and datasheet can't be found on the internet. I figure it out +in, -Vcc, +Vcc, Out, but chip has connection to extern tone controle circuit (bass, treble). How to connect STK to this?
Please if someone could give me some advice or post SI1125 datasheet.
Thanks very much in advance!!!
Miodrag Pejin
pejinm 12th January 2007 10:22 AM
Anyone???:confused:
Maybe I should just use power supply, casing, VU metar, inputs... from the amp and put in LM3886 devices?
Hope someone will reply...
Regards...
Resources saved on this page: MySQL 18.75%
