Todays brainwave - why not use appropriately rated Zener diodes as rectifiers ?.
Anybody tried this and what results ?. Eric. |
#2 |
Disadvantage: more noise
Advantage: ??? Why? |
#3 |
Exsqueese me but what on earth for?
Only way would that not be to use Zeners that have a zener voltage higher than your maximum reverse voltage and then some? Otherwise would they not conduct both directions and discharge the caps they really should be charging? God knows what would happen... There are so many sweet diodes out there like standard, schottky and what have you. Why Zeners? /UrSv PS. If anybody is afraid of switching noice then why double it? |
#4 |
Electrons are yellow and more is better!
What is the real difference really? Lower reverse voltage breakdown, but what else? OK, zeners are a little bit different, the doping(*) is more, in order to get lower breakdown voltage.
(*)I mean put material into the silicone as a "polution".
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
I think they are a lot slower, i.e. more capacitance, so their use as rectifiers would not be good as compared to a diode designed for use as a rectifier.
#6 |
You'd be better off with some decent high-current fast recovery diodes, with bypass caps across them to dampen the little bit of noise that'll come off the junctions when they start to conduct.
oO |
| Screen grid zeners; which? | Klimon | Tubes / Valves | 37 | 10th March 2008 01:52 AM |
| Please Help!!! Decoupling Zeners | arupg | Solid State | 22 | 31st August 2007 07:16 PM |
| Should I use high voltage value zeners or multiple lower voltage zeners in series? | jarthel | Parts | 7 | 30th May 2006 04:56 PM |
| bosoz psu ?? blown zeners ?? | dqswim | Pass Labs | 1 | 9th October 2004 02:30 AM |
| Zeners For Input Question | vdi_nenna | Pass Labs | 4 | 1st April 2001 07:30 PM |
| Page generated in 0.07976 seconds (76.52% PHP - 23.48% MySQL) with 10 queries |
