Old 30th May 2006, 01:42 PM   #1
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Default Transistor base negative voltage
I would like to ask , is it bad if a transistor's base is driven with negative voltages(up to -10V) in amplifier circuit , when amp is clipping ?
What maximum negative base voltage is allowed for BC547 ?
Best Regards,
Lukas.
Old 30th May 2006, 01:49 PM   #2
Did it Himself
richie00boy's Avatar
If you look at the datasheet, you have 3 voltage ratings:
Vce (collector-emitter) - basically the max device voltage
Vcb (collector-base)
Veb (emitter-base)
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 30th May 2006, 01:58 PM   #3
Thanks.
I understood that i should limit max. negative base voltage to -6V (transistor's max. Vbe is 6V).
Lukas.
Old 30th May 2006, 02:18 PM   #4
Did it Himself
I am not sure. Just because the limit of base referred to emitter is 6V, does not mean that it can also withstand that much in reverse bias. At least I think.
Old 30th May 2006, 02:24 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
In general, you don't want to allow the base emitter to go into reverse breakdown. I'd clamp it lower than the expected reverse breakdown voltage.
That's why the 2SC2878 muting transistor is special. It is designed for high reverse emitter base voltages, and they still fail. They tend to get leaking in funny ways that test good.
-Chris
Old 30th May 2006, 02:27 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
The B-E junction will zener at about 7V (in an NPN) if driven negative. When that happens, the current needs to be limited to a few mA or damage will occur.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 30th May 2006, 02:28 PM   #7
Did it Himself
Interesting. What about the EF Type II output stage where the driver can reverse bias the output? They seem to survive OK - lots of Leach amps and AKSA amps and others and you never hear of them breaking.
Old 30th May 2006, 02:42 PM   #8
janneman's Avatar
Well, first of all, drivers and output transistors are more robust so probably they can survive higher reverse currents - the outputs for sure. Also, if they are driven by a Vas stage, the current is also inherently limited which may save them.
Jan Didden
Old 30th May 2006, 02:47 PM   #9
Vbe max is the limit when driven into saturation in the normal direction.
I would treat that as an absolute limit unless the manufacturer is more forthcoming. Maybe 70% of absolute for normal operation when saturated.
The reverse (-Vbe for NPN and +Vbe for PNP) voltage will be different and could be much smaller.
How about adding a parallel diode to short the reverse current past the junction and thus produce a volts drop across the preceeding resistor.
regards Andrew T.
Old 30th May 2006, 02:54 PM   #10
janneman's Avatar
The reverse is normally around -7 (NPN) for zenering to occur. But it is a very noisy zener.
There was a time when reverse biased B-E junctions were used as noise sources in test equipment.....
The forward is normally not a problem as long as the base current is not exceeded. What will happen is if you increase normal Vbe is that the Vc will get lower and lower until at saturation Vce will be just a couple of mV (in a small signal transistor). Actually, base current will then start to flow directly into the collector because the B-C junction becomes forward biased.
Jan Didden
What about FETs for Cellular Base Stations in Audio Cascode Voltage Gain Stage (line tiefbassuebertr Solid State 8 23rd August 2009 02:53 AM
base-emitter voltage clovi_kate Solid State 7 22nd March 2007 08:20 AM
base voltage Leolabs Solid State 1 3rd June 2006 11:00 AM
negative voltage doubler for ccs Jaap Tubes / Valves 6 6th February 2006 05:32 AM
Transistor current souce, negative supply Zodiac Power Supplies 2 31st December 2005 04:47 PM
Page generated in 0.10580 seconds (80.14% PHP - 19.86% MySQL) with 11 queries
